who sells cheap strocker cranks for ls1's?
1 Post
SGI supposedly now makes a nodular iron 4.00" stroker crank for LS engines. They also make a forged 4340 one. They also make some nice looking 6.100 and 6.125 SBC Severe Duty I-beam and lightweight I-beam rods that'll work in our motors if you get pistons that use .927 dia pins.
They're imports i'm sure but so is eagle, scat, compstar, and K-1.
Here's a link:
http://www.sgiperformance.com/pdf/webcateloge.pdf
Pg 4 for the cranks
Pg 6 & 7 for the rods
Here's a link:
Pg 4 for the cranks
LS1Tech Premium Sponsor
4" will put you at 382 cubes. The 3.900 stroker crank has been discontinued by eagle
We stock the 4" stroke cranks, and we can put together a complete rotating assembly for you! Give us a call if we can help.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
