Cam card question
Old Jan 23, 2009 | 04:32 PM
Zach79Z's Avatar
Default Cam card question
ordered my 230 230 612 592 custom grind throguh vengeance from comp and the cam they sent me is a 230 230 613 591. Vengeance is closed and idk what to do or if the cam card is wrong or if itd even matter. Any suggestions?
Old Jan 23, 2009 | 04:41 PM
Zach79Z's Avatar
Also just looked the lobe numbers up on the cam card they match the ones they were suppose to be but neither say xfi or xer
Its says 3016R /3725R but it was suppose to have xfi and xer lobes
Old Jan 23, 2009 | 04:44 PM
JPH's Avatar
JPH
What's wrong? I would degree it? Thats where your going to find if somethings wrong anyways?
Old Jan 23, 2009 | 04:45 PM
Zach79Z's Avatar
the lift is .001 off and i didnt know if it would make a differnece
Old Jan 23, 2009 | 05:06 PM
405HP_Z06's Avatar
This small amount doesn't make any difference.
3016R - XFI intake lobe
3725R - Xtreme Energy XE-R lobe
Old Jan 23, 2009 | 05:07 PM
Zach79Z's Avatar
Ok just wanted to make sure it wasnt differnt. Thanks
Old Jan 23, 2009 | 05:09 PM
chrs1313's Avatar
you are fine that is the right cam...my intake and exhaust lift are the same...it is really hard to cut a cam 100% to the thousandth...
so as of now you got sent the right cam...now you just have to degree it when you put it in to make sure it was cut right...I am sure you will be fine...
also when you degree it, it is acceptable to be within a +/- 1 degree...so it could be a 229 or 231...
Old Jan 23, 2009 | 05:23 PM
Zach79Z's Avatar
cool. Thanks chris and 405 hp z06
Old Jan 23, 2009 | 08:25 PM
405HP_Z06's Avatar
Good luck on your install, I hope all goes well.
Old Jan 23, 2009 | 08:47 PM
Zach79Z's Avatar
Thanks so do i
Old Jan 23, 2009 | 10:23 PM
Shawn MacAnanny's Avatar
my 236/235 .651/651 cam specs as a 235/235 .649/.649, you're doing fine man
