Trex with 3.73s and an SS3600 - Acceptable?
I guess what it comes down to is I want to find out what cam will make the car run the fastest with 373s, 3600 stall, 26" tire, and a 200 shot of nitrous
ms4 isnt necessarily "better" than an ms3... it all depends on your setup, a ms4 could run worse or better than an ms3 in any given setup.. i have the ms4 and love it... but in your situation, i would say an ms3 would better suit your setup..
im changing to a 28" though for that reason..
I too am running a decent sized cam (G5X3) and a 3600 stall.. 1st,2nd i can barely keep in on the road if i hit it hard from a stop or @ 30mph... Like your's, mid range, up top are icing on the cake.. I hope to get a little more from my FAST 90/90 that i am installing this weekend..
It has been said b4... match the gears,stall,cam together.. so they are working together 4 ya.
GL..
410's in an A4 is overkill if you plan on driving it on the hwy.. IMO!! but, it's your car! Do what YOU like...
i installed my ported 90/90 and i picked up 35rwhp.... i felt that too..
i drive about 50-70 miles a day... mods were listed earlier.. ms4, 4k stall, PRC ls6s, 410s, etc... as long as you dont have to run over 60mph for extended period of time it isnt bad at all.. at 60mph im a hair over 2k rpms.. if you have to drive over 60 for quite a while on a DD driven car with 410s, i wouldnt recommend it.. to me it is well worth the performance gains..
you have to consider this.. you can put 410s in with a 28 inch tire.. and it will help bring your ratio down just at tad, better than 373s... OR you could run 373s with a 26 inch tire and have true 373s.. ALSO! say your cars race weight is 3500lbs and you have a 4k stall... the converter is going to flash to about 43-4500 depending on the converter... BUT! if you have a 3150lbs race weight with the same 4k stall you car is going to only be flashing 4100-4300..
the more weight you take out of the car, the lower the stall flashes too.. not a HUGE difference, but every bit counts.. just something else to factor into your decision..
like said i do... and wouldnt trade it for anything.. although like said, im going to a 28 tire.. i get out of the hole good enough now... im light and my converter flashes very high.. so i can take the little bit of loss in gear ratio..
when i go to my th400 i will be going with a 4400-4600... i will be spraying a nice shot, so i dont want to go too much over that..
what size shot you spray?
the wider fenders help the T/A fit wider tires more easily..
i dont know... maybe it is? but that isnt what ive picked up.. give TSP a call yourself and find out first hand... then relay that **** back here! haha..
your powerband is going to be different with a ms3 and ms4, along with street manners, rpm idle, shift points.... i just dont se how you could view it as somewhat the same cam.. they are completely different..
FWIW, i make just as much power as people with trex cams.. the trex and the ms4 are almost identical cams.. the ms4 a SMUDGE smaller, but better manners, and easier to tune for most..
if it were me, i would of course go with the ms4... i LOVE mine.. and if your going 410s, the only difference in what were talking about is our stall.. you with a 3600, and me with a 4k... but mine does flash a higher than that...
let me know if you want to know anything else about my setup or anything...
although, depending on your tire size, i am going to call BS on 160+.. with a 26.5inch tire your top speed is going to be right around 135...
have you had your speedo recalibrated? if not, it is way off.. mine said i was doing over 160 on the way to the dyno, got it tuned and on the way back my speedo stopped right around 135..
+1.. same here..
+1.. same here..
Matt
