Trex with 3.73s and an SS3600 - Acceptable?
i had 3.73's and and a 4k stall, 3rd pulled like a raped ape (1st and 2nd sucked due to street tires
)... never got a chance to run it at the track tho... ms4
4k stall
410s
26" tire
i wish i would have went with more stall.. something like a 4400-4600..
i dont suggest this setup to someone that runs the 1/4 though... top speed is about 135ish.. i only run 1/8, so its no biggie to me.. but in the 1/4 on spray you would be at your top speed..
i would HIGHLY recommend more converter for that cam..
there honestly is no reason to go with that cam if you want those gears and that stall size.. you wont be using all the cam.. also keep in mind those cams LOVE to breath up top.. reason most of them are matched with ported 90/90s and rev high..
is there any reason you can choose a smaller cam? something like a ms3 would match almost perfectly..
(J/K!) ms4
4k stall
410s
26" tire
i dont suggest this setup to someone that runs the 1/4 though... top speed is about 135ish.. i only run 1/8, so its no biggie to me.. but in the 1/4 on spray you would be at your top speed.. ..
I too am running a decent sized cam (G5X3) and a 3600 stall.. 1st,2nd i can barely keep in on the road if i hit it hard from a stop or @ 30mph... Like your's, mid range, up top are icing on the cake.. I hope to get a little more from my FAST 90/90 that i am installing this weekend..
It has been said b4... match the gears,stall,cam together.. so they are working together 4 ya.
GL..
410's in an A4 is overkill if you plan on driving it on the hwy.. IMO!! but, it's your car! Do what YOU like...
