Trex with 3.73s and an SS3600 - Acceptable?
it stays in 3rd so you dont **** your transmission up.. its good it wont shift to OD... your transmission would get WAY too hot..
i looked into it because i was pissed about it at first.. and then once i did my research i was happy about it..
i would get someone to tune it to where it wont allow OD in WOT.. it is NOT a good idea at all.. and i would rather lower my top speed than replace my tranny..
if you want to know more about it, just do some research, there are quite a few threads about it..
but like said by both.. i would much rather that, that ruin my trans..
when i was in overdrive i had a burning smell in my car for a while so yes it gets reallll friggin hot.
this is taking for granted your arent going ridiculous speeds, and doing stupid stuff.. normal 1/8 and 1/4 racing, and or DD
How does it overheat the trans though? If it did how do cars hit their top speeds if not WOT? I understand the transmission output shaft (and therefore planetary gear sets and holding clutchs) are spinning extremely fast, but that would be a speed issue, not a load issue. So it would be basically like saying you just can't go over that MPH, WOT or not.... guess I'm off to do research too
and yes i was in D.. when i first tried to get my top speed.. i kicked it.. it pulled EXTREMELY hard to the 130-140ish mark and then just stopped.. it for SURE didnt run out of power (i have plenty of that) it just ran out of gear.. i tried it 2-3 more times after that.. i thought the same thing as you said, i thought maybe i hit my shifter into 3 or something.. but i didnt.. did 3 more pulls and same thing every time.. went back and told a buddy and he said it was set like that to save my tranny from over heating and destroying itself, asked a car buddy that rebuilds trannys and he said same thing.. then i came on here and did some research, same answer..
