GM LSX-L92 Small Bore Cylinder Heads
#61
There is a lot more to velocity numbers than port size. The fact that is has a 2.00 intake valve means the throat should decrease a considerable amount in size after the short turn radius. That alone will make a huge difference.
#64
I found another wrinkle in what some of the experts been telling us with a set of 4.00 inch bore L92s for small bore motors. http://www.edelbrock.com/automotive_...chevy-ls.shtml
Look about halfway down as the super vic carb intake saying about knotching into the block to fit l92 heads. Not optimal fitment I am sure with valve shrouding, and i bet yu would wanna stroke your lil 5.7 to 383 to take advantage of your new found breathing either way. I see this maybe being a cheaper by far and saying you did it thing.
#65
I build custom Pontiac engines for a living and some of our engines can use 2.11 intake valves with 5.3 liter size bores with notching and a lot of them came from the factory with notched cylinders so it does work and doesn't seam to hurt our motors too bad fwiw
I think the mast heads are great as an option for HOT 346's but more towards the 366-395 strokers imho but 2500$ without springs eek!
I was hoping they would make a smaller port head aimed at street/strip head for cars and trucks that would flow 330-340ish as cast and could sell complete for 1800-2000$ I think that would be a winner because in order for me to buy a set they need to beat all cathedral heads in the same price range, idk, we can hope LOL
#73
I don't know for sure yet. I just saw them advertised on PACE's website for $840 each, and it says they ARE available. I sent PACE a message asking if this was correct.
#74
Yes, they are availiable.. GM's Lansing PDC has them in stock with a list price of $875ea.. This includes valves but no springs.. Also, they are listed in the 2010 GM catalog on page 202.. They aren't pictured, but it does have the part# & info on them. Hope this helps.
#77
Here is what i got off crateenginedepot...
LSX/L92 #19201807
L92/LS3 port configuration
Produces from 356-T6 Aluminum with 5/8 thick deck
6 Bolts per cylinder, Aluminum construction
Runners are in as cast condition
250cc intake port and 80cc exhaust port
70cc Chamber size
Intake flow = 280 CFM@.600 / Exh flow= 180 CFM@.700
Assembled with 2.00 Intake and 1.555 Exhaust Valves
Beehive springs
15 Degree valve angle
3.890 minimum bore size block
Uses LS3 / L92 rocker arms
Requires the LS3 / L92 intake manifold
Looks like they are going for $799 a head. Has anyone tried these yet? Are these overkill for an stock cubed LS1/LS6?
LSX/L92 #19201807
70cc Chamber size
Beehive springs
