Loud ticking from head area
Old Jan 26, 2009 | 08:54 PM
CamaroSS22's Avatar
I wouldnt see why not. Should see a nice little gain out of it too. You may want to think about a cam if you're already doing all this.
Old Jan 27, 2009 | 12:26 AM
uLs1a's Avatar
Does anyone know the part number for the LS1 lifter?
Old Jan 27, 2009 | 12:33 AM
Soul TKR's Avatar
i gave it to you over on LS2.com
Old Jan 27, 2009 | 12:35 AM
Soul TKR's Avatar
http://www.ls2.com/forums/showthread...3#post11113383
Old Jan 27, 2009 | 12:37 AM
uLs1a's Avatar
I did not see that
Old Jan 27, 2009 | 12:45 AM
Gregorya24's Avatar
get ls7s http://www.texas-speed.com/shop/item...d=690&catid=50
Old Jan 27, 2009 | 12:57 AM
PowerTalk's Avatar
Make sure its not just a spark plug has worked itself loose. Seriously
Old Jan 27, 2009 | 01:04 AM
Soul TKR's Avatar
he's got a good point... the simple check is worth a shot...
but my money is still on a lifter...
Old Jan 27, 2009 | 02:30 AM
f-bodyguy's Avatar
yea possiblya spark plug and if it is a lifter shoot dunnowhothisis a pm he has some stockers laying around
Old Jan 27, 2009 | 12:30 PM
Havok2's Avatar
when we swap lifters, since i hear the noise only on the driver head, should i swap them all out? or its ok if i just swap the driver ones?
Old Jan 27, 2009 | 08:28 PM
Soul TKR's Avatar
it would be ok just to swap out the one side... but why? at this point, you've already pulled the head, drained all the coolant... unbolt the other head bolts and put the new lifters on both sides...
Old Jan 27, 2009 | 08:58 PM
  #32
uLs1a's Avatar
Can I use the stock 7.4" push rods with the LS7 lifters?
Old Jan 27, 2009 | 09:05 PM
  #33
Soul TKR's Avatar
i don't see why not Chris.... seeing as the LS7 lifters have replaced the LS1's...
Old Jan 29, 2009 | 09:14 PM
  #34
christrusler's Avatar
if you have any questions when you do the work, pm me and i'll give you my number
Old Jan 31, 2009 | 12:37 AM
  #35
uLs1a's Avatar
What causes a lifter to collapse?
Old Jan 31, 2009 | 01:27 AM
  #36
OffspringZ28's Avatar
subscribing
Old Jan 31, 2009 | 12:13 PM
  #37
SOMbitch's Avatar
You may as well replace the lifter trays as well $30-$40
Not saying this will happen but it could wipe your cam lobe and lifter spins in the tray coming apart and sending crap through the whole motor. I wouldn't drive til it's fixed personally.
Old Jan 31, 2009 | 12:17 PM
  #38
WS6.Jay's Avatar
Anyone have pictures of a collapsed lifter or how to check for it? I have been having this same problem for over a year, I just parked the car in the garage and took it apart and it's been sitting there for like 9 months... I just finally pulled the driver side head today and pulled the lifter and they seem fine, the only thing I can find is 1 or 2 small nicks at the top of the lifter cup on 2 of the lifters, could be just part of the casting though.
I haven't pulled the passenger head yet because I was almost certain the driver side was the problem.... is there any way to test them ?? Or would it be obvious which one is the problem?
Old Jan 31, 2009 | 12:35 PM
  #39
slowpoke96z28's Avatar
maybe they can be tested by air pressure at the port the oil goes into and see if the cup responds? i would use the regulator to turn the air pressure down to say 10 or 20 psi if you do it.
Old Jan 31, 2009 | 02:07 PM
  #40
uLs1a's Avatar
I have to make a 115 mile drive home in two weeks so I can get the heads off and change somethings out, Im just hoping I make it
