Loud ticking from head area
Old Mar 5, 2009 | 08:31 PM
  #61
futuref-body's Avatar
ls7 lifters in. ticking stopped, no more surging, and engine in general feels tighter/more responsive IMO.
Old Mar 12, 2009 | 07:33 PM
  #62
TURBHOE's Avatar
12 Second Truck Club
how bad does a push rod have to be bent to make a noise? i replaced my springs and lifters and still have a noise. its gone while at idle but with any load it comes back. i pulled the coild wires one at a time and noise would not go away. the best way to describe it is if you had a slide hammer that didn't slide smooth. so it would make a ssslllliiidddeee noise until it hit the end and it would dink. or tick ssllliiidddee dink sslliiddee dink
Old Mar 12, 2009 | 11:56 PM
  #63
69_YENKO's Avatar
unhooking the coil wire wond work because the Cam is still spinning the valve train. I dont think it would need to be bent very much. the bend it basicly making the overall length of the pushrod from end to end shorter and a short pushrod is taking preload off the lifter. I will say yours is obviously bent bad enough that its rubbing the edges of the guide hole in the heads AKA that "ssllliiidddee dink sslliiddee dink" sound your hearing.
Old Mar 13, 2009 | 07:28 AM
  #64
TURBHOE's Avatar
well, i disconnected the coil packs to see if it was a rod bearing or not. i think she's gonna sit until i get a ls6 cam and new longer push rods.
