Loud ticking from head area
Old Jan 31, 2009 | 02:23 PM
  #41
FlashLCD33's Avatar
First things first - add oil to full and see if it goes away. The lifters are hydraulic, meaning oil pumps them up. If you're low on oil, the lifter may not have enough flow to pump up.
Second - why would you replace one lifter for $60 when you can buy all 16 LS7 lifters for around $120? I just had a lifter fail after doing a cam swap, and just finished replacing the lifters. It is a fairly easy job if you can turn some wrenches.
I personally opted to drop the motor/kmember since I have access to a lift. You're going to need a torque wrench and a long breaker bar to do the head bolts. You're also going to need a power steering pulley remover, so you can take the power steering off of the DS head. Also a shop vac is nice when you're scraping the head gasket off of the block so you don't drop chunks of gasket in the coolant holes.
GM reccomends using "special sealant" on the head bolts. It is just plain ole blue threadlocker. The new head bolts will come with a sealant on them, but I put blue threadlocker on them as well.
Where the red rags are are where your lifters go, under the heads. It's not necessary to lift the motor up, I was pulling the pan to change the oil pump o-ring.
Old Jan 31, 2009 | 03:33 PM
  #42
Soul TKR's Avatar
Originally Posted by uLs1a
I have to make a 115 mile drive home in two weeks so I can get the heads off and change somethings out, Im just hoping I make it
just take it easy Chris... you might wanna think about adding a "breakdown/tow" coverage on your insurance, or pick up AAA... for the trip just in case...
Old Jan 31, 2009 | 10:13 PM
  #43
uLs1a's Avatar
I did add oil and the ticking did not go away, but it does burn oil pretty quick.
Wes I do have AAA
Old Feb 1, 2009 | 09:41 PM
  #44
69_YENKO's Avatar
Originally Posted by WS6.Jay
Anyone have pictures of a collapsed lifter or how to check for it? I have been having this same problem for over a year, I just parked the car in the garage and took it apart and it's been sitting there for like 9 months... I just finally pulled the driver side head today and pulled the lifter and they seem fine, the only thing I can find is 1 or 2 small nicks at the top of the lifter cup on 2 of the lifters, could be just part of the casting though.
I haven't pulled the passenger head yet because I was almost certain the driver side was the problem.... is there any way to test them ?? Or would it be obvious which one is the problem?
when my lifter took a crap on me you could not tell by looking at it, the thing just wouldn't pump up and hold pressure anymore. a new set of GM replacement lifters ("LS7's" if you want to call them that) is only $130 new. I would pull the other head, change them all and not look back, especially since the car has sat for 9 months, who knows if all the others will pump up after sitting so long. good luck let me know what you figure out with it.
Old Feb 7, 2009 | 12:34 AM
  #45
uLs1a's Avatar
I ordered new head gaskets, new head bolts and the "LS7" lifters....what about pushrods? Or should I not worry abou those?
Old Feb 7, 2009 | 12:50 AM
  #46
69_YENKO's Avatar
do you already have aftermarket hardened PRs? as long as they aren't bent(roll them on a perfectly fat surface)
or otherwise visibly worn or messed up I wouldnt see the need to replace them. you might just check that the oil passage/hole through them isnt clogged up
Old Feb 7, 2009 | 03:32 AM
  #47
Soul TKR's Avatar
Chris... it really just depends on what you plan on doing with this engine of yours... if you plan on doing a whole new build on a different engine since this one's mileage is getting up there... just keep the stock pushrods in it... pull them, roll them on a table to make sure they don't "wobble" (sign of being bent)... if they are fine, put em back in...
otherwise, if you plan on building THIS engine up... go ahead and put some hardened ones in while your in there... they aren't TOO expensive... but I know things are adding up already...
Old Feb 16, 2009 | 08:52 PM
  #48
TURBHOE's Avatar
12 Second Truck Club
is this a lifter too?
and does any body have a part number for a set of bolts. my parts guy said he could only seem to get them in singles. i need the ones that are all the same length 2004 and newer.
Old Feb 17, 2009 | 06:17 AM
  #49
TURBHOE's Avatar
any body?
Old Feb 20, 2009 | 12:46 AM
  #50
Rede's Avatar
I might be late in chiming in, but I too had a ticking noise on my driver's head.
After pulling the valve cover, my buddy got me to pull my pushrods and inspect them.
Turned out that I has scuff marks on all of them. The pushrods from the last two cylinders were hardly noticeable while the second cylinder was really noticeable.
When I rolled them on a piece of glass (mirror works too), all of them were slightly bent, even the passenger side. I replaced them with a used set that I bought for 50 bucks that had less than 3000miles.
I babied the car for the rest of the year and did a heads/cam/LT's swap while it was all apart over the following spring.
If you had the heads off, doing a cam swap would be a lot easier as you don't have to worry about the lifters, just pull them out.
Hardened pushrods sure wouldn't hurt either...
Old Feb 20, 2009 | 09:39 PM
  #51
98cherrySS's Avatar
Hmm. Scuff marks... I have a slight tick and scuff marks from the guide plates...
Rede, when you replaced the pushrods did the tick go away?
Old Feb 21, 2009 | 09:07 PM
  #52
Greg Pippin's Avatar
Originally Posted by christrusler
Yup, it's the lifter, just had to change one of mine, pull the head, inspect all the lifters on that side, you should be able to easily spot which one is bad. A lifter from the dealer is around $60, you'll also need head gasket $25, and new head bolts $25. Do NOT use the old head bolts.
go to (gmpartsdirect.com) the stock LS1 lifters will be around 35.00 each.
Old Feb 21, 2009 | 11:20 PM
  #53
Cape T/A's Avatar
Umm.... LS1s dont have guide plates.
Old Feb 22, 2009 | 12:07 AM
  #54
98cherrySS's Avatar
I have PR guide plates for my Crane 1.7 RR's... I have scuff marks at the contact point of the PR and the guide plate... Accompanied by an intermittent ticking.
Old Feb 22, 2009 | 10:29 AM
  #55
Cape T/A's Avatar
Ok, i gotcha now.
Old Feb 25, 2009 | 07:21 PM
  #56
futuref-body's Avatar
uLs1a-we sound almost identical! the sound, replacing the water pump about a week before, and it burning oil. idk what you are, if that affects it, and if it happened to you but im an A4 and when im in fourth and give it just enough gas before it downshifts, the car starts surging like its cutting in and out.
Old Feb 25, 2009 | 08:05 PM
  #57
uLs1a's Avatar
Yup same as mine and I am an A4. I should hopefully have the car up and running on saturday so I will let you know. Like I said I swapped out the lifters and pushrods. I bought he LS7 lifters and Comp Cams chromemoly 7.4pushrods
Old Feb 25, 2009 | 10:59 PM
  #58
01pewterSS's Avatar
i have the same sound.. i checked pushrods and rockers... this weekend going to check the lifters... hopefully it fixs the problem too..
Old Mar 2, 2009 | 09:52 PM
  #59
i finally pulled everything off. a few lifters and lobes of the cam have "marks" from where it looks like little metal pieces would have scarred it but besides this my lifters are perfectly fine so idk where all the metal shavings are coming from and if my new lifters will even fix my problem. i rolled my rods on a piece of glass and they are bent ever so slightly that i dont think that would cause the problem either.
Old Mar 2, 2009 | 10:39 PM
  #60
Soul TKR's Avatar
could be metal from your pushrod journals maybe...?
