take a look at this 6.0 please
Are the newer 6.0 motors the same as the 2000 on up?? I know 99 and
2000 had a crank difference. I would like to put a 6/speed behind this.
So, is there any difference I should know about?? THANKS
if its 317 it should still be 24x, it they are 823 then they are l92 and more thsn likly will have 58x, and will not work with fbody pcm or harness.
u will need a 24mm socket and breaker bar. it helps if u remove the plugs, but turning it over does not guarantee that the bearings are not hurt.
if it binds too much it may be damaged
76 camaro conversion with a 6/speed, so that should be alright, right??
I was gonna send the harness off to speartech to delete what was not needed.
Ill go back tomorrow and pull the cover.
Z06 cam in it, and a F-body oil pan, put it in the car and get it running
and driving. I know I would need f-body front pulley accessory also. Then
find a 98 to 2002 T-56 to mate up to it.
like most place's want to hit you up for
$1500.00 no trans. Don't need it anyway.
