Is there a big difference between an off-the-shelf cam vs a custom cam?
I've fairly new to which company makes the better cams (I know in regards to Mustangs, a lot of car owners tend to go with FTI) when it comes to LS1s, so I've been looking around at some of Ed Curtis' cams.
My goal is to dyno 400 at the wheels with the combo in my sig and the stall. The car, first and foremost, will be my daily driver but want 11-second capabilities NA.
Are there any noticable difference between taking an off the shelf cam that should run well with a engine combo as opposed to buying a custom cam that will run well with an engine combo?
I'm still months away from this but want to go ahead and decide if I should look at an off the shelf cam or look for a reputable company to have it built for my specs.
Thanks
http://www.thunderracing.com/catalog...&vid=3&pcid=51
We do extensive dyno tests on every cam prior to releasing so it performs as we want it to. The fact that we sell the same cam more than once doesn't make it a mediocre cam that is somehow inferior to a one off cam. Many of the "custom" cams you see on here are already running in someone else's cars that asked for custom cams. The cam worked well so they recommend it again to another customer with similar mods. There is no difference in this and a shelf cam. Just that shops like us purchase several at a time to have them on hand.
Either way you want to go, we can get you a cam to meet your goals for your car. With the right supporting mods, you can get the car into the 11's and still have it daily driver friendly. Feel free to shoot me a PM or give me a call with any questions!
Jon
