224 on XFI lobes vs TR224
Old 02-06-2009, 02:46 PM
SOMbitch's Avatar
Originally Posted by ballerchris510
Im in your same boat and i was looking at the el torro wich is a 230/230 612 592 111lsa which is xfi/xer lobe... but instead i was wonderin how maybe a 230/232 612 595 111lsa xfi/xer would perform and if gains against the 230/230.... or maybe SOMbitch's cam 230/234 612 598 on a 111lsa?? what would the extra exhaust duration do compared to the 230/230??
Since I am running cats I needed a little more on the exhaust side. It would help if you ever plan to spray too. My 111LSA is advanced 2* BTW.
Old 02-06-2009, 09:21 PM
Redlinez's Avatar
I've been thinking about a 224/228 609/59X 111 lsa 108 icl XFI/XER for my set up.
Old 02-07-2009, 09:47 AM
rickssz's Avatar
Originally Posted by XtraCajunSS
I've cut many custom grinds based on XFI lobes and have had very good results with them. They are more stable than XE-R lobes WITH more lift... a win-win in my book.
Thanks,
Shane
Just curious if an xer cam is has 600 lift and an xfi cam has 600 lift all else being equal how does the xfi have more lift?
Old 02-07-2009, 10:03 AM
melchoir's Avatar
That's not how it works. Basically, if two cams are offered at the same duration we'll use 224 for now, the 224 xfi cam will have a higher lift than the 224 xer cam.
Old 02-07-2009, 10:27 AM
BrokenWs6's Avatar
not a cam expert by any means but I believe it has something to do with the xfi lobes having a greater ramp rate than xer lobes, hence the higher lift at the same duration.
Old 02-07-2009, 12:28 PM
Nitroused383's Avatar
That cam would be a good lower rpm torque cam but it would be really peaky and not carry past peak very well would make peak hp around 6000rpm. I would set it up on a 111 LSA 110 icl. This would center the overlap over TDC and would make peak hp around 6200-6300 rpm (LS6 intake ideal peak) and it would rev well past peak since the overlap is centered. The 108 icl would have a IVC of 40 degrees and +2 of intake biased overlap, this would make it a real peaky cam that falls off, probably good for a truck though lots of low end torque.
Old 02-07-2009, 01:07 PM
Redlinez's Avatar
Funny thing, someone else recommended the exact same lsa/icl as you. I guess I'd better go with the 110 icl Now if I could figure out what to do with my Dart 225's.
Old 02-07-2009, 03:27 PM
Ryan L's Avatar
Yeah, the 224/230 xfi tends to be 'peaky', but the area under the curve is solid. I made peak power ~6300 rpm with LS6 heads, which sounds high, but HP was within 5 from 6000-6600 with no real drop off.
Old 02-07-2009, 04:05 PM
Chris Gage's Avatar
as far as a great street cam, I love the 224/230 111+1 xfi cam. I made 387 with stock 98 heads, ls6 intake and the dyno pulls being stopped at 5800 rpms do to the driveshaft popping out and I expect this cam to peak at around 6300 and pull out to 6700 or so. I have no doubt that with a 243 head or even porting my head would net me a substancial gain as well as finishing the tune. My power at 3k was right around 200rwhp/370rwtq
Old 02-07-2009, 05:14 PM
ballerchris510's Avatar
what icl does yours have i was thinking 109icl?
Old 02-07-2009, 08:24 PM
Redlinez's Avatar
I made 396/379 on 87 octane, LS6 intake, all bolt ons, 4.10 geared 10 bolt with the 224/228 581/581 112 XER cam about 5 years ago.
