228/228 cam with .558 lift what springs ?
like tittle says what spring set up to i need .. unless i can run stock springs but im sure i cant ..
what lift will stock springs be no good at ?
will zo6 heads with springs have enough lift for this cam ?
thanks for the info and i anyone has cheap ones for sale let me knw .
We do take Master card, Visa, and Discover.
You can either call us up 1 800 456 0211 or go to our website and order them, which is where that hyperlink in the other post will lead you.
Thanks
John
Thanks
John
DO NOT trust them that high. Although they may be capable of that, then do they have the right spring pressure for something over .600, which include some pretty nastly lobes nowadays? I would only recommend them to .610 max
Seems like a damn good price. $122 for new springs that will take my TR230 with ease (.581/.565 lift)
I have not looked at them, but we have seen some problems like valve float happen when you go too much lift, ie over 610 on the pacs we have. I would def look at spring pressure on those over 6xx and see if they are adequate like alot of the higher pressure springs are. That is the most crucial part.
none at all. those springs are top notch. they have alot more pressure than the regular conical (beehive) style. I would also def use them with the titanium retainers, i mean if you buy the kit, they come in there anyway.
