question on head install
Old Oct 12, 2003 | 03:22 PM
pdd's Avatar
pdd
Default question on head install
do i need to remove the intake manifold to just do a head install or can i leave it on?
Old Oct 12, 2003 | 04:20 PM
AZLS1's Avatar
Default Re: question on head install
It needs to come off. You can't get to the small head bolts with it on.
Old Oct 12, 2003 | 05:55 PM
eallanboggs's Avatar
Now if you were driving a TAD with a Fontana block you be OK.
Old Oct 12, 2003 | 06:22 PM
jmX's Avatar
jmX
Considering the intake is bolted to the heads, I'd say there is no choice but to remove it.
Old Oct 12, 2003 | 07:20 PM
Scalpel's Avatar
Follow the install to the letter here: http://www.ls1howto.com
Old Oct 12, 2003 | 07:28 PM
Tin Indian's Avatar
I'm getting a bad feeling about this install
Old Oct 12, 2003 | 07:33 PM
DaleMX's Avatar
Study up on this a good bit before you try it. Better yet, get a good shop to do it for you.
Old Oct 12, 2003 | 07:36 PM
Scalpel's Avatar
lol
Old Oct 12, 2003 | 09:23 PM
pdd's Avatar
pdd
o boy. give me sum credit here. i did the cam install and it cam out perfect and i already installed the ls6 intake last yr. i just wanted to save sum work thats all. anything beside the fuel line removal tool from gm to get the fuel line off. maybe somethin homemade. just dont feel like waitin for the part to come in. last yr i pried it off with a screw driver but that was a bitch
Old Oct 12, 2003 | 11:26 PM
2xLS1's Avatar
Any good auto parts store should stock a set of fuel line disconnect tools like these for under $10. http://www.toolsource.com/ost1/produ...J74FSANH406EEB I got a set just like those at O'Reillys. They work on Ford A/C connections too.
Old Oct 13, 2003 | 07:27 AM
jmX's Avatar
jmX
Yup, I've never seen an autoparts store that didnt have a fuel line disconnect tool for a GM. And if you are just replacing the heads, you can just unbolt the intake manifold, but leave the fuel line disconnected. The intake can be set aside far enough so that its not really in the way of the head install. I'd recommend getting the disconnect tool though, since it's so easy.
Old Oct 13, 2003 | 09:42 AM
robertbartsch's Avatar
Ive done it with and without the fuel rails attached....MUCH easier to remove the fuel rails...
