what injectors
Old Feb 18, 2009 | 03:16 PM
1fastmofo's Avatar
Default what injectors
anyone know what injectors i need for my setup stock bottom end and bore 98 ls1 w tsp 2.5 5.3's, w a torquer v2 specs are 233 239 598 603. other specs are fast 92/92, custom built lt's, yank 3400, 4:10 gear. would svt 42's be too much
Old Feb 18, 2009 | 03:27 PM
gayslowassNALSjunk's Avatar
42's would be fine.
Edit: I don't remember the Torquer v2 specs being that large.
Old Feb 18, 2009 | 03:49 PM
1fastmofo's Avatar
hmm well thats cool cause maybe i can say hey its just a little v2 lol
Old Feb 18, 2009 | 04:18 PM
I meant that the torquer v2 specs aren't that. The 233/239 is a another cam.
Old Feb 18, 2009 | 04:43 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I agree on the 42#'ers
Just incase you want to add a little juice down the road
Old Feb 18, 2009 | 09:03 PM
405HP_Z06's Avatar
Bosch Design III 36 lb/hr @ 3 bar (41 lb/hr @ 4 bar) will be plenty with a little room to grow. The 42's are overkill.
Both sizes are the same price. Fuel Injector Connection has these for $239 a set. Great injectors that are easy to tune.
Old Feb 18, 2009 | 09:08 PM
JFM-jr's Avatar
Those are the brand I am going with when I am ready for injectors^
Old Feb 23, 2009 | 01:41 PM
1fastmofo's Avatar
aaron, what about if I add spray I say at most a 150 shot?
Old Feb 23, 2009 | 09:18 PM
405HP_Z06's Avatar
Wet or dry?
Old Feb 23, 2009 | 09:34 PM
PONTIAC SLP's Avatar
with 36lbs injectors u will be fine . if u want to add some spraying i recommend u to run with any aftermarket fuel pumps 255 and 36lbs.
Old Feb 24, 2009 | 12:17 AM
1fastmofo's Avatar
im going to say wet from what I have read... I already have a 255 walbro
Old Feb 24, 2009 | 07:46 AM
chris23120's Avatar
ls1's rule
Old Feb 24, 2009 | 10:55 AM
405HP_Z06's Avatar
You are okay with a wet kit. It supplies it's own fuel so it doesn't affect injector size. It will however affect your fuel delivery system, i.e. fuel pump.
Old Feb 24, 2009 | 01:59 PM
1fastmofo's Avatar
good deal thanks man
Old Feb 24, 2009 | 09:34 PM
1999FirehawkLS1's Avatar
hell buy 50lbs it wont matter just dont under shoot as long as u get a good tune it wont matter if ya over kill alittle
Old Feb 25, 2009 | 02:20 AM
why 50lbs ? wasting $$$ on those big injectors , 36lbs is good choice and he will be fine and safe with that
Old Feb 25, 2009 | 02:41 AM
stevied916's Avatar
It matters; you can go too big and will have problems at idle. Stick with close to the size you need.
Old Mar 16, 2009 | 05:12 PM
1fastmofo's Avatar
these are the ones i got thanks again man
Old Mar 16, 2009 | 11:00 PM
01ssreda4's Avatar
i agree, i was gonna suggest SVO 30s which are about 36 at our pressure.
Old Mar 17, 2009 | 01:07 AM
2002 SS's Avatar
torquer v2= 232/234 .... i was thinking of just getting SVO 30# with my T.2
