6.0L truck motor
so is this truck 6.0 pretty much the same thing as like an ls2 but just a cast block. so normal ls heads will work, i guess the truck heads are not quite tuned to run in a car or go very fast
unless your road racing i cant see the extra 80 pounds is really going to matter. and look at it this way. with a 4 inch bore stock or larger if you bore it, you can run l92 heads (ls3) and l76 intake and make sick sick power with a cam for cheap! if its the dished pistons though id definately tear it down and replace those and the rings/bearings at the same time. hell id just go ahead and buy a 402 rotating assembly and be done with it all LOL...
