Found the ultimate "Old Man Cam".
Old Dec 2, 2002 | 05:45 AM
  #61
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Default Re: Found the ultimate "Old Man Cam".
Any word. I saw the other thread on TR doing a Z06 with a TR227/224...
Just curious
Old Dec 2, 2002 | 08:33 PM
  #62
Modsquad's Avatar
10-Second Club
First, thanks for a great thread with lots of valuable info :thumbsup:
Also, as someone else posted, how well would this cam work with stock LS1 heads? I'm also interested & I'llhave stock heads, LS6 intake (02 Trans Am), LT's & ORY with the double springs & chrome molly push rods?
Is there a cam with similar characteristics but with a little less lift?
I don't plan on getting heads for a while but if this cam will work well with both stock & S/2 heads I think I've found the cam for my setup.
Thanks Patrick for contributing all this info as well as you other guys that 'know your stuff' Thanks in advance for your thoughts & wisdom! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Marc
Old Dec 3, 2002 | 01:34 PM
  #63
Grunt's Avatar
Patrick,
You have a good technical background and know your stuff, but please do not call this an "Old Mans Cam". I'm 58 and the guys I ran with and still do from the 60's like lopey cams and loud exhaust. We could not be acussed of sneaking up on anyone. Just beat them fair and square. We want everyone to think the worlds comming to an end when we pull up. Just my 2 cts.
Old Dec 4, 2002 | 04:26 PM
  #64
Scalpel's Avatar
Would Comp 987s hold up to this cam? Do we have a definate yay or ney on the lifters holding up to this?
Old Dec 4, 2002 | 10:31 PM
  #65
bparker's Avatar
"Are we there yet"??? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Dec 9, 2002 | 01:24 AM
  #66
bparker's Avatar
OK - is this going to happen or what?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by gator's 99TA:
<strong>i got an email and jason from TR said they are scheduled to install one of these cams in an M6 so as to put out a dyno graph to the net and public. so i guess we will still have to wait.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old Dec 9, 2002 | 02:28 PM
  #67
gator's 99TA's Avatar
well i was the one that got the email saying they are going to install one, but again, no word on anything yet. TR will wait untill they have all the bugs out and get the programing perfect first before releasing info.
as for Patrick G, dont know why he doesnt just give us a dyno of his. most here are smart enough to understand an auto's dyno graph wont look pretty, but shows important info.
Old Jan 10, 2003 | 03:19 PM
  #68
J-Rod's Avatar
Still waiting on answers...
ttt
Old Jan 18, 2003 | 08:28 AM
  #69
ToplessTexan's Avatar
<img border="0" alt="[gruffy cottonball]" title="" src="graemlins/gr_gruffy.gif" />
Old Jan 18, 2003 | 03:13 PM
  #70
Scalpel's Avatar
<img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old Jan 19, 2003 | 09:07 PM
  #71
soslo's Avatar
October 15th - original post - my excited
November 15th, December 15th, January 15th - nothing.
It's been 3 months, I'd expect em to release the info on this cam by now...unless it doesn't live up to the original expectations (I hope it *does*).
This is the cam I want - and TR still doesn't have any info on their site. <sniffle>
Old Jan 19, 2003 | 09:32 PM
  #72
Fenris Ulf's Avatar
Have you called TR?
Old Jan 20, 2003 | 12:07 AM
  #73
Jason99T/A's Avatar
I can shift faster than you.
OK guys here is the latest on the "Old Man Cam":
We have a 6-speed car with all the bolt-ons scheduled for install on this cam in early February. We were going to install it in December, but we have decided to wait on the Comp dual valvesprings that will fit in the factory spring pocket with no modification. These should be out for testing very soon. They are going to be a "dual" Comp 918 and they are expecting this spring to be very stout. We feel these will be better choice than the 918s since they will handle a little more lift and will be able to setup with more closed/open pressure. We had the option of going with a less agressive intake lobe and running Comp 918s, but decided against this since would defeat the whole purpose of this cam choice.
The 918s may work with this cam, but we would definitely not feel comfortable running them in this application.
Look for some new information in the coming weeks.
Jason
Old Jan 20, 2003 | 08:43 AM
  #74
This sounds like you're aiming for use with stock heads, correct? Are the REV duals not a viable option? If I'm having a set of heads worked, wouldn't I just have them set up for BMF duals and be done with it? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Thanks! Looking forward to good results from this design. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 21, 2003 | 12:38 AM
  #75
PAULJ99Z's Avatar
How's this for an "Old Man Cam" setup with good reliability:
* 218/220 Duration cam on a 114 or 115 lobe center, .527-.530 lift
* 1.8:1 ratio rocker arms (.560" lift)
* 2002 ZO6 valvesprings
* Lightweight 2002 ZO6 intake or Titanium intake valves, stock exhaust valves.
* Titanium retainers
Result, a very durable setup using proven components, more valve motion, less lifter acceleration. This should net about 400 RWHP with the right heads and other bolt ons.
Paul J.
Old Jan 21, 2003 | 12:46 AM
  #76
Patrick G's Avatar
LS1 Tech Administrator
Sorry guys. I can't help you with dyno sheets for the SS. When we installed the cam at Thunder Racing, we did a quick before and after dyno. The prelimary numbers with the 230/224 cam were much lower than they had been before (in the 360 rwhp range). The 215/220 cam was installed an dynoed. It made more power than the 230/224 cam up to 6400 (sometimes 15-20 rwhp better). After 6400 rpms, it died quickly. I never got the dyno sheets. I always planned on re-dynoing the car and getting some hard evidence, but I would up selling the car December 7th. There won't be any dyno mumbers from my car I'm sad to say. The M6 from Thunder Racing will be better for a before/after comparison since mine wasn't up to full strength when it was tested.
Patrick
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Feb 8, 2003 | 06:52 AM
  #77
Keep Hope Alive! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Jason, any comment on whether you are targeting this cam at stock heads? I'm puzzled about the spring issue. (BTW, any update on the Comp duals?)
Old Feb 8, 2003 | 09:55 AM
  #78
NoOne's Avatar
How would this cam work out on a turbo engine?
I'm in the process of pulling it all apart for a refresh and thought of changing cams to get something that would offer a bit more down low until the turbo's spool up.
Little less choppy than I have and a bit easier to tune around.
I'm not sure what is in there right now as ARE never gave me exact specs but its a larger split duration.
Old Feb 28, 2003 | 11:31 PM
  #79
stangkillin99ss's Avatar
well its almost march...do we have a dyno sheet yet??? <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Feb 28, 2003 | 11:38 PM
  #80
Jason99T/A's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by stangkillin99ss:
<strong> well its almost march...do we have a dyno sheet yet??? <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">https://ls1tech.com/ubb/ultimatebb.p...c;f=1;t=011007
