^^^^looks like u need a front bumper as well.
My camaro had like 140k before i took it apart. ran fine but started making a little noise towards the end....but i was beating the **** out if at the end too.
My 98 has 208,000 plus and still show no signs of slowing down. Like they said it all depands on how the car war takeing care of.
My 98 is a 120k and I've got a H/C/I/E setup so... I don't drive it but maybe 3 hours a week so...
Holy Crap, I thought it was rare to get that high on an engine, I guess not. Thank you guys, when it happens I will let you all know.
i got one, 99' stock internals just took the motor out of it with 185k on it and tore the whole thing down for ***** to rebuild it and my block/internals couldn't have looked any better. i didn't beat the hell out of it but i didn't baby it either. take care of them and its normally a pretty good bet theyll last.
jmilz28
close
- Join DateFeb 2005
- LocationHouston, TX
- iTrader Positive Feedback100
- iTrader Feedback Score(13)
- Liked:125 Times in 94 Posts
Corvette is a different animal, bro. Yeah, engine is the same, so is tranny, but it's everything else that will get you. C5s have a bunch of different modules and are wired in series. Batteries leak, like in f-bods, but the acid hits the PCM/harness. Topless? If the car was wet, a BCM or seat module will **** you up. Headlight motors, alternators, windows, and everything is MUCH more complex on Y than F cars. The mechanical is fairly reliable (I have 167k hard miles on mine). The electrical on that car will ruin you...
Changing fluids (ALL of them), filters, and cleaning injectors and top end are key. You MUST be preventative. If you are, the mechanicals on these cars are good 200-300k. If not, expect them to be good to 100k and then it's all on borrowed time.
YMMV but I worked in a Chevy dealer service department for years and saw LOTS of LS cars over time, in addition to taking care of my own. There's more than one meaning to the Corvette tax. Don't say you weren't warned.
Feh, I got 223,XXX miles on mine. Goin' on to 224K. It's still running pretty strong, albeit rough idle. It used to be a cop car, so it wasn't babied. BUT, it WAS well maintained. It's due for a full tune up this coming week though. Every fluid in the car is being changed out. Good luck to you and your LS1 and enjoy!
Also, you MIGHT want to clip that passenger side clip for the air lid :p. That sucker will fall right off! haha
jmilz28
close
- Join DateFeb 2005
Good stuff right here! Good maintenance will offset some abuse fo' sho'! I'd bet with a PROPER injector flush and decarb of the top end, new plugs and fuel filter - your idle smooths out a lot. Seen it many times, I like the BG stuff myself.Originally Posted by FirebirdWS86
Feh, I got 223,XXX miles on mine. Goin' on to 224K. It's still running pretty strong, albeit rough idle. It used to be a cop car, so it wasn't babied. BUT, it WAS well maintained. It's due for a full tune up this coming week though. Every fluid in the car is being changed out. Good luck to you and your LS1 and enjoy!Also, you MIGHT want to clip that passenger side clip for the air lid :p. That sucker will fall right off! haha
