How Many Of You Have Had Problems W/Cylinder #7?
#7 for me as well. Ringland broke and it cracked the block all the way through.
http://www.fquick.com/videos/viewvideo.php?id=3432
i wasnt aware of this until mine broke, than i read it happens every now and then... I think gm has a tsb that says use a different set of rings, and it gives a gm part number...
a lot of people say that well its not worth Changing out the "Injectors" all i have to say is 1 thing. If your'e to Cheap to buy a set of New Injectors get a Set of Gto "Injectors" there on here and on cars at ur local scrap yard . This ususally is like what there saying light/or heavy mods or stock redlining and then the Engine goes lean trying to keep up addiquite fuel flowing thought the combustion chambers.Then Dam #7 IMo with tuning with Hp tuners and all the ls1's in Vegas.
#32
After FAST 92 install and re-tune. First run at the track. Busted No.7 piston and split the cylinder wall. 26K miles. Pics here:
https://ls1tech.com/forums/generatio...-disaster.html
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
#34
my number 7 let go too. i never exactly figured out what happened.
when i put my new motor together i had my SVO injectors cleaned and flowbenched, and i made sure to put the 2 highest flowing ones in 7 and 8
#35
UNDER PRESSURE MOD
Knock on wood, I haven't had any issues, but just like everyone is saying, I put my highest flowing injectors in the back and worked my way forward going from 7 to 8, then 5 to 6, ect. Also, I keep my tune via wide band at 12.5:1 on the street, which on the dyno would probably read more like 12.2:1 because of less load. It may seem to rich, but time and time, people have shown that running 13:1 might not cause knock, but it will be a matter of time before you hurt #7.
