ws6 cam install
Old May 2, 2009 | 10:22 PM
98camZ's Avatar
Default ws6 cam install
hey im doin a cam install on my 2000 ws6 and i was wondering if anyone knew how much air to pump into the cylinders to keep the valves up?
Old May 2, 2009 | 10:41 PM
willyfastz's Avatar
Restricted User
At least 100psi
Old May 2, 2009 | 10:48 PM
ramdaspadhye's Avatar
Do what?
Old May 2, 2009 | 11:21 PM
Paint_It_Black's Avatar
Make sure you lock down the muffler bearings too. Don't need that spinning while you change your cam.
But seriously.. go to office max and buy a case of compressed air. Put the little red nozzle into the spark plug holes and have 8 friends spray the compressed air in. Now, you have to get the cam out before the compressed air cans run out, so work fast!
Old May 2, 2009 | 11:40 PM
mike13's Avatar
Also use a socket on top of the retainer and give it a couple of taps with a hammer. It breaks the locks loose when you compress the spring. Otherwise what happens is when you compress the spring the locks stick and let the valve open.
Old May 2, 2009 | 11:42 PM
jrpimp00's Avatar
WTF>>> Dude Ive seen about 3 or 4 people do it with no less than 75 PSI. Even though I would just use rope and put the piston at TDC. .you should be safe with 75-90psi...
Old May 3, 2009 | 12:02 AM
98camZ's Avatar
so 75 to 100 psi
Old May 3, 2009 | 12:06 AM
dopy's Avatar
I used the TDC method for changing the valve springs. For the cam swap I removed the rockers and push rods.
You need to worry more about the lifters dropping
Old May 3, 2009 | 12:08 AM
Raptor_WS6's Avatar
i did it with 125 psi
Old May 3, 2009 | 12:13 AM
I was just joking with my posts, listen to these other guys.
Old May 3, 2009 | 12:45 AM
98camZ's Avatar
hahaha i was wondering but i knew you were joking i was bout ready to call you a dumbass
Old May 3, 2009 | 01:04 AM
