How long do I need to crank to get oil pressure?
I just finished a heads/cam install and was trying to prime the oil pump by cranking the car with the plugs removed/coils unplugged/fuel pump relay out, etc. How long do I need to crank the motor to prime the pump? I've turned it over for a combined 30 secs or so but I'm not seeing any oil at the rockers.
Okay thanks for the info. I just pulled the oil pump back off. Before doing so I turned the engine over with the front cover off and saw oil seeping down from the drive gear onto the crank shaft snout. Should it be doing that?
I pulled the oil pump off and the o-ring didn't look damaged at all so I'm not sure why I wasn't getting oil to the top of the motor. Any ideas?
I didn't actually check under my valve covers before firing mine up, but I did crank it over in 3 10-12 second intervals. My gauge never showed oil pressure while cranking which was odd, but I went ahead and gambled after plugging in the injectors. Fired right up and had great oil pressure. If everything with your oil pump seems fine and you're 100% sure you did nothing wrong, I'd say fire it up.
Edit: I oiled up my o-ring with STP Oil Treatment and also put some oil in the pump itself and then bolted it up. If you lube up the o-ring it should slide right in with no issues.
when i did a complete engine build i didn't see oil pressure when i cranked it either, but when i started it about 3 sec into running it had great oil pressure, so dont panic if it doesnt have pressure for a couple of sec when you first start it
