A Flooded Street vs. LS1
Old Jun 2, 2009 | 11:51 AM
  #101
BIG_MIKE2005's Avatar
Originally Posted by Mart00SS
Because both the rear axle and Transmission have a vent hole that if fully submerged will allow water to get into and contaminate the fluids and thats bad.
I would say from my personal experience you'd have to sit still in water deep enough to completely submerge the rear & tranny for it to seep in & it wouldn't happen real quick either. I have drove thru plenty of water I probably shouldn't have & never had a tranny fluid or rear end fluid problem.
Granted I do not suggest driving thru deep water but sometimes if thats the only way thru you just gotta hope for the best or go back home.
Old Jun 2, 2009 | 05:06 PM
  #102
WS7_FORMULA's Avatar
where is this "vent hole"?
Old Jun 2, 2009 | 05:32 PM
  #103
jattgunman's Avatar
Pull off your tps(throttle postioning sensor) on your throttle body and spray it with some electrical cleaner..
Old Jun 2, 2009 | 05:39 PM
  #104
PREDATOR-Z's Avatar
That and a TPS relearn
Old Jun 2, 2009 | 05:41 PM
  #105
Mart00SS's Avatar
I wouldnt worry about where it is, but depending on how high the water was when you stalled out and how long it sat there. If the water was high enough to come into the car through the doors then I would worry about them being contaminated but if not I'd say youre fine.
Old Jun 2, 2009 | 05:56 PM
  #106
andrew69_04's Avatar
cant MAP sensors cause funny idle conditions too? i know on a nissan truck a buddy had back in the day his MAP was causing high idle. Also, i would recommend changing ur trans fluid and rearend gear oil. i would rather spend my money on 4 qts of ATF and 2 QTs of gear oil then to find out water might have been in there and destoryed your tranny. it wont have any noticable effects right away, but water in oil will take its toll. might not hurt to check it out.
Old Jun 2, 2009 | 07:07 PM
  #107
Thanks for the consideration on the trans n rear end oil change. I will check it out after the fixed idle...its low its idling at 800 rpms...thinking its the IAC motor. I moved the **** and the idle changed
Old Jun 3, 2009 | 12:35 AM
  #108
00SS6spd's Avatar
I've been saying to check the TPS for days now Hahaha
