Valve Spring & Pushrod Help needed...
Old Jun 6, 2009 | 02:27 PM
frankmarroquin's Avatar
Default Valve Spring & Pushrod Help needed...
Where can I find the cheapest Hardened Pushrods and Valve Springs to Support only 600 Max Lift. My cam is small and I am going for a budget build so every penny saved will help. Thanks guys.
Old Jun 6, 2009 | 03:12 PM
slt200mph's Avatar
You should check with the vendors located on the right hand side ... you are in texas so try texas speed and performance they will treat you right... they have a spring and push rod package that will work for ya.
http://www.texas-speed.com/shop/
Old Jun 6, 2009 | 06:59 PM
Thanks.... anybody else have any other sources that can be helpful.
Old Jun 6, 2009 | 07:18 PM
LCplmarine98's Avatar
com[ 918s are pretty cheap and the TR brand prs are pretty cheap too. try thunder racing and ws6store.
Old Jun 7, 2009 | 01:11 AM
slt200mph's Avatar
Just start checkin out the sponsors on the right hand side of the page ... do not skimp on valve springs ... 918s have had numerous failures in the past...this equates to expensive repairs...do some research and check you prices with sponsoring vendors and make an infortmed purchase ...
Old Jun 7, 2009 | 03:52 AM
TransAmcoupe98's Avatar
Need the size of that cam, because 600lift on a cam is not that small. If you have a cam with 580ish or 590ish lift, get the duals.
Old Jun 7, 2009 | 07:32 AM
slt200mph's Avatar
Patroit Gold duals or PRC duals are a very good choice with a long life and at good price ... I have put 40K miles on a set from both companies .... one on a cam with .598 lift and the other on a cam with .588 lift ... both were still in spec when I replaced them ...
Old Jun 7, 2009 | 11:00 AM
SOMbitch's Avatar
PAC 1218's would be a direct replacement and being a beehive you can reuse your current locks and retainers. PAC1218>Comp918
Old Jun 7, 2009 | 01:45 PM
beedo's Avatar
I installed pac springs too, Skoggin Dicky for 130.00 something shipped to my door
Old Jun 7, 2009 | 04:30 PM
Cape T/A's Avatar
Budget builds shouldn't involve the internals of an engine. The end.
Old Jun 7, 2009 | 07:06 PM
slt200mph's Avatar
Well said sir ...
Old Jun 8, 2009 | 09:15 PM
Cape T/A's Avatar
Thanks, lol.
Old Jun 15, 2009 | 09:03 PM
Cams lift is only 581.....
Old Jun 15, 2009 | 09:16 PM
SOMbitch's Avatar
^^^^^^You already got your answer.......
Old Jun 16, 2009 | 03:25 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We stock the pac 1218 springs & pushrods kits for a very very reasonable price. Give us a call & we can put together a package for you!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
