AFR 205's OR Stage 3 GTP ported 862
Old 06-13-2009, 06:58 AM
jaber911's Avatar
Default AFR 205's OR Stage 3 GTP ported 862
what the best heads for lq4 6.0L stock end
Stage 3 GTP ported 862 (4.8/5.3) castings
66 cc chamber
2.055/1.570
LIFT INT EXH
450 291 221
500 310 227
550 328 231
600 342 233
650 346 234
700 353 236
AFR 205's 66cc
thanks
Old 06-13-2009, 09:01 AM
STEEPSS's Avatar
What else is going to be on the car? You will have lower compression with the LQ4, due to the negative dish in the pistons. What are your plans for the car? What is your budget? If you're looking for help, give as much info as you can.
Old 06-13-2009, 09:57 AM
allngn_c5's Avatar
More info needed bro ............
Old 06-13-2009, 11:21 AM
jaber911's Avatar
first thanks for all
i have lq4 stock (6.7 dish piston )
i wanna milled any best heads to 61 cc
with gm gasket 10.7:1 SCR 8.32 DCR compression
custom camshaft 221/233 . 610/ .617 113+2 lsa
the engine for daily use N/A
now what the best heads for me
thanks
Old 06-13-2009, 11:56 AM
99blancoSS's Avatar
AFR's hands down. I've got them on sale as well
Read the stickie, its not just about a flow number.
Old 06-13-2009, 12:37 PM
corvet786c's Avatar
I just bought AFR 205's last week now I am broke.But when you do a mod like this I believe you should do the Best. It will be worth it.
Old 06-13-2009, 04:56 PM
allngn_c5's Avatar
TFS 215's are a good option as well. Mill for compression and don't forget you need the Yella Terra UL's as well. Big hp from these heads. Can't go wrong with AFR 205's either.
Old 06-13-2009, 05:00 PM
james562's Avatar
I have a hard time believing anyone got those flow numbers out of factory 5.3 862 castings
My vote is if your gonna spend the money for AFRs you might as well grab a set of Trick Flow 215's or even the new PRC 215 head
Old 06-14-2009, 03:41 AM
LilJayV10's Avatar
Given I don't know a lot about LS engines....I know alot of people love the AFR heads, just like alot of people love the FAST intake. The price on both are high and I think there might be better options. Again I am just an internet racer with no real life experience with either.
I would rather have my stock heads ported by TEA or someone else that know what they are doing that buy a set of 205AFR's.
Let the flame begin.
Old 06-14-2009, 06:43 AM
allngn_c5's Avatar
Good luck getting your stock heads to flow like a set of afr 205's or tfs 215's without hogging them out. Even if they do flow better on paper, they will most likely be dogs on the street until you into your power band. (No lowend grunt) JMO
Old 06-14-2009, 09:37 AM
5.3LJimmy's Avatar
What are the cc's of the intake and exhaust ports on the GTP heads?
Quick Reply: AFR 205's OR Stage 3 GTP ported 862
