TEA 5.3 Stage 1.5 Heads any good?
Old 07-01-2009, 09:39 AM
  #41
sams_robert's Avatar
Texas Speed has 2.5 5.3L w/ a cam for $1609 .......... i do not have track times yet but with the 228r cam it runs like a beast...........
Precison Race Components Stg 2.5 5.3L Heads & Cam
Item# 199-PKG1
Precision Race Components 5.3L Stage 2.5 Cylinder Heads Fully CNC Ported & Assembled With Stainless Steel 2.02" Intake Valves, 1.575" Exhaust Valves, & PRC Dual Valve Spring Kit with Titanium Retainers. Kit Also Includes TSP Hardened Pushrods & Your Choice Of Camshaft!!
Old 07-01-2009, 10:16 AM
  #42
Intercooler2's Avatar
Only one downside I can see to 5.3 heads and I don't know all the specs but they may not be good on a larger bore should you ever go that route. If you buy the LS6 head you are covered?
Old 07-01-2009, 10:56 AM
  #43
transaman98's Avatar
I read an article in HPP about the PRC 2.5 5.3's and a 224/230 .581/.588 114 lsa cam and they were only able to click off some low 12 second passes. That depressed the hell out of me and I don't really think the highest of those heads after that. I also know that that is only one car but I guess I just expected more out of that setup(especially since the only difference between the cam they ran and mine is the exhaust lift. Theirs is .588 and mine is .592) I want to get my next setup to run 11.50's n/a, and reliable.
Old 07-01-2009, 03:00 PM
  #44
man...I just checked my email and TEA sent me a message. I guess they are out of stock of the 243 cores so if I want to do the 2.0 LS6's from them I am going to have to purchase a set of them used somewhere. All of a sudden those 5.3's aren't looking so bad...
Old 07-01-2009, 06:20 PM
  #45
steelers71's Avatar
I have been very happy with my 5.3's. Mods and time in sig. weight reductions are front swaybar and spare tire and jack removed.
Old 07-01-2009, 07:08 PM
  #46
man that is impressive. I think I just need to get with a shop that really knows how to get me a full weight car to run 11.50's with a heads and cam setup on top of what I already have for supporting mods.
Old 07-01-2009, 08:37 PM
  #47
98blueSScamaro's Avatar
Just do your home work and you will be there befor you know it.
Old 07-01-2009, 08:38 PM
  #48
Dam get that car to a low 1.50 60 and your in the 10's for sure in setup
Old 07-02-2009, 05:57 PM
  #49
firefighter813x's Avatar
I had a long conversation with TEA recently and they had me leaning towards the TFS 220 as cast heads. I should have bought the stage II LS6's when they had the cores. I'd rather spend a little more and not have to worry about PTV clearance too. I think the 1.5's are 1450 or so? TEA was telling me that the PTV on the 1.5's with my X1 would be pretty close. They recommend 228 or less on the intake. The TF heads need the PR's and rockers which add up to about 500 or so. At that price you're close to AFR's too. I'll never be able to choose a cylinder head when the time comes.
Old 07-02-2009, 06:05 PM
  #50
tell me about it. However it would seem that I am going to be picking up a set of 243's for a pretty good price. Enough to make it cheaper than paying $1800 for the heads and work from TEA. So I hope I am making the right choice going this route. I just need to make a damn decision on what my goal is for the car and start piling up parts...
Old 07-02-2009, 08:55 PM
  #51
lol- good luck.
Old 07-03-2009, 07:30 PM
  #52
JaSSon's Avatar
Those numbers are on a brake. I would love to launch my car like that but I basically have a stock tranny with a vig 3200. As far as the flow #'s they are available on TEA's website. I am just trying to educate myself on what would work best for my setup and my driving habits(primarily street use). Whichever head will perform the best given my setup. If I need to swap out my cam while I am doing the head swap I would be more than happy to. I just need a little guidance on putting the setup together.
With my stock tranny, VIG3600, 3.73s I ran 11 teens at full weight. Drove this setup all over Texas. Ive been running the same motor setup for over 4 years now.
Quick Reply: TEA 5.3 Stage 1.5 Heads any good?
