Noise??
Old Nov 13, 2003 | 02:28 PM
onebadz's Avatar
Default Noise??
Hey guys I was just wondering if yall could help me identify a noise that my car is making. When I crank it up after it has sat a while it makes this noise like teeth chattering or a knocking sound, Going by predetor I have no knock retard and this noise disipates when the car gets up to operating tempeture but the noise is still faint. Is this just a case of piston slap? Thanks for the info guys.
WeS
Old Nov 13, 2003 | 05:00 PM
2001CamaroGuy's Avatar
what "kind" of "knock" is it?
its probubly just piston slap as you said.......
rod bearing knock would not "go away" and is a very "solid" kind of "thump thump thump" and valve train noise (valves, collapes lifter, pushrod, etc..) is a "tick tick" sound....
Old Nov 13, 2003 | 08:10 PM
onebadz's Avatar
Like I said it is more like a ticking noise kind of like a loud teeth chattering but my car runs fine and has suffered no lose of power.
Old Nov 14, 2003 | 09:39 PM
if its a tick, its probubly just the valve train
Old Nov 15, 2003 | 10:49 AM
onebadz's Avatar
So do you think that its anything out of the normal. Thanks
WeS
Old Nov 15, 2003 | 05:08 PM
wouldn't think so......
You said it goes away (or at least dies down) as the motor heats up and thats typical (normal/ok/etc....all good ) for motors. Because the LS1/LS6 is an all aluminum motor (block and heads), sounds carry through the engine MUCH louder than an iron block (think of a bell.... ) so what you are HEARING is going on in every other motor in the world (pretty much).
IF....you really really start to get parinoid, you could always take the valve covers and rocker arms off and check to see if you have any bent pushrods (it happens....even on auto cars). But I really think your good and don't need to worry about it any more.
Get some cutouts and leave them open.......you won't be able to hear ANYTHING anymore (jk)
Old Nov 15, 2003 | 05:20 PM
onebadz's Avatar
Thanks man I appreciate the info.
Old Nov 15, 2003 | 08:53 PM
sure thing.....
hey....how bad do your Richmond 3:73s whine? I have a set and they don't seem all that bad (can't hear them at all till 55+ MPH) but other people who own then always bitch. Just wondered..
