Storing LS1 engine
Old Jul 9, 2009 | 06:22 AM
mad4evr's Avatar
Exclamation Storing LS1 engine
Hi guys
I'm going to study abroad for four years and I have Ls1 engine newly rebuilt and I want your advice on the way that I should store it!!
Old Jul 9, 2009 | 07:54 AM
Sid447's Avatar
Google search,
for "engine inhibiting" as it's too lengthy to describe easily.
Old Jul 9, 2009 | 04:29 PM
01ssreda4's Avatar
yeah do some searching on the net. obviously any steel has to be protected from moisture so it doesnt rust and gaskets have to be protected from drying out. I would also assume you would put the motor in a "ziplock" bag to protect it from dust etc.
Old Jul 9, 2009 | 05:41 PM
DaddySS's Avatar
There are bags specifically made for wrapping engines etc. for storage - rust inhibiting/drying agents lined on the inside of the bag.
Old Jul 9, 2009 | 06:40 PM
mad4evr's Avatar
Red face
Thanks guys!!
I've searched google for some tips but they confused me more...So what I did few hours ago --> I filled the engine with oil and wrapped it with a bag!!
and all the holes are closed with gasket or with tape..If any one have any additional advice I'm willing to hear them
Old Jul 9, 2009 | 08:40 PM
crainholio's Avatar
I usually change the engine oil and run it a few minutes to circulate the new stuff. Then loosen all 16 rockers, blow a whole can of storage fogging oil down the intake, and all 8 spark plug holes. Put plastic bags over the throttle body mouth and both exhaust pipes, held on by zip ties so they don't come loose.
Old Jul 10, 2009 | 04:45 AM
vettenuts's Avatar
Is this engine in or out of the car. For that long a period, I would personally remove the rockers to unload all the valve springs. If you go to Wal Mark, you can buy a plastic tub and put the rocker in the tub and fill the tub with oil.
Old Jul 10, 2009 | 05:00 AM
mad4evr's Avatar
**Note: The engine is not installed yet and have not started since it was rebuilt.... **
