Inexpensive LQ4 Pistons?
Old Jul 13, 2009 | 05:09 PM
chopperloco's Avatar
Default Inexpensive LQ4 Pistons?
Who offers the least expensive pistons for a low buck LQ4 rebuild?
Need not be forged.
Thanks again.
Dominic
Old Jul 13, 2009 | 05:14 PM
NemeSS's Avatar
speed pro, 400$ with rings. up to .060 bore
im at 490rw with those pistons, pressed to stock rods, stock crank
Old Jul 13, 2009 | 06:56 PM
Buttz1969's Avatar
I got the Speed Pro slugs for about $225 from my machine shop and I picked up the rings from Summit for just under $100.
Old Jul 13, 2009 | 07:29 PM
Default Thanks Men!
Good stuff.
Old Jul 13, 2009 | 08:49 PM
Speed-pro part #?
Old Jul 14, 2009 | 05:27 AM
Buttz1969's Avatar
I've got the part numbers saved at work. I'll get them for you today.
Old Jul 14, 2009 | 05:28 AM
SunOfZ's Avatar
i would like those part numbers too! ;o)
Old Jul 14, 2009 | 07:05 AM
Buttz1969's Avatar
Pistons: Speed Pro H857CP
Rings: Sealed Power E921K
Like I said, I got my pistons from my machine shop for about $225, but if you search around you can find them on the web for about the same. I have never ordered anything from them before, but enginekits.com has them for $250 and the rings for $100.
Old Jul 14, 2009 | 12:19 PM
Great!
@$24 each(summit)
These are dished i was kinda hoping for a flat top.
Old Jul 14, 2009 | 12:40 PM
Buttz1969's Avatar
Good luck on finding the flat top pistons for cheap. That would be the LQ9 (or LS2) pistons. I also wanted to go flat top, but they are quite a bit more expensive.
LQ9 Piston from Speed Pro: H1129CT ($375 from RockAuto)
Note that these are also designed for a floating pin (not pressed like the LQ4) so you will likely need different rods as well.
Another option if you have a stock bore (4.00") would be to seek out a set of used LS2 pistons. I have seen a set with rods go for as little as $150 on eBay.
Old Jul 14, 2009 | 02:44 PM
SunOfZ's Avatar
i like the prices so far. also what inexpensive rods are out there?
Old Jul 14, 2009 | 03:19 PM
Rods:Scat i-beams less than $300 with arp bolts...
Buttz1969's Avatar
Best I found when I was considering this were the Scat rods. They have a press fit version and a bushed version.
Scat Pressed: 26100944P
Scat Bushed: 26100927
These both go for around $300.
Again, a used set of LS2 rods may be a better way to go (financially) especially if you are keeping things rather tame.
Old Jul 14, 2009 | 04:28 PM
NemeSS's Avatar
u can get around 10.5-10.7 scr with lq4 pistons and milled 243 or 241
im around 10.7 with milled 243, .060 over lq4 pistons.
flat top not really necessary. and the dish has bit more of ptv clearance than a flat.
