Cometic install
Old Jul 22, 2009 | 07:32 AM
Intercooler2's Avatar
Default Cometic install
Any special install prep? On my Buick I used Copper spray but don't know if it is needed on the LS. Everyone use the stock torque sequence and specs?
Old Jul 22, 2009 | 09:14 AM
conan's Avatar
I didn't use any copper spray on my cometics, (some do) I just wiped the block, heads and head gaskets with some brake cleaner and put the heads on. Torque specs... I used gm's torque order and arps torque value for the studs. If your using gm bolts torque them to oem specs.
Old Jul 22, 2009 | 09:52 PM
Stock bolts. Any leaks?
Old Jul 22, 2009 | 09:54 PM
brad8266's Avatar
I cleaned the **** out of the decks and used 2 thin coats of copper spray, sealed perfect.
Old Jul 22, 2009 | 10:01 PM
conan's Avatar
No leaks here, I do use studs over the bolts. I have also removed the heads and reinstalled them on the same gaskets too. What ever you decide to do take your time and clean the **** out of the decks and heads with brake or carb cleaner. Also before you start cleaning blow all the head bolt holes in the block out with air.
Old Jul 22, 2009 | 10:07 PM
Thanks for the tips!
Old Jul 24, 2009 | 09:26 AM
New Patriot heads so should be okay there. I will get some GM Top Engine cleaner to do the block. What's the latest verdict on using spray? I did a search and some do/ some don't.
Old Jul 24, 2009 | 09:34 AM
JonatRLMS's Avatar
we copper spray all mls gaskets
Old Jul 24, 2009 | 10:55 AM
Looks like it can't hurt. Only found one post of a guy said he block was being eaten or something to that effect. He didn't post back so I have no idea what he was talking about!
Old Jul 25, 2009 | 08:18 AM
Bill Bowling's Avatar
I sprayed my a year ago. No leaks.
Bill
