Gm MLS Vs Cometic .040 compression
Old Jul 24, 2009 | 08:09 PM
mtuggle86's Avatar
Default Gm MLS Vs Cometic .040 compression
Ok I know theres a write Up but i really on CR but I really couldnt decide where my setup would be I have a stock 01 ls1 short block Im putting Stock Ls2 heads on it and Im trying to figure out what will be the difference In compression using the cometic .040 headgaskets vs the stock mls head gaskets .057-.059 compressed with the ls2 heads
BtW its going with a tr224 cam How much power will the heads be worth vs stock 241's
Old Jul 24, 2009 | 08:14 PM
DaddySS's Avatar
Old Jul 24, 2009 | 09:09 PM
mtuggle86's Avatar
I really dont know how to word it any different
Old Jul 24, 2009 | 11:00 PM
405HP_Z06's Avatar
I think this is what your looking for:
With .040 head gaskets:
With GM MLS .051 head gaskets:
Old Jul 25, 2009 | 02:41 AM
mtuggle86's Avatar
Thanks alot
Old Jul 25, 2009 | 07:03 AM
vsocks1's Avatar
Aaron,
Can you run your program on my combo? My setup is LS6 with TFS heads milled to 60cc with Cometic .040 gasket. The only tricky part is that I flycut my pistons to a depth of about .100" on the intake valves only. Cam is 232/236 .595/.578 113+3. Not sure what my compression is now afterwards.
Old Jul 25, 2009 | 08:33 AM
405HP_Z06's Avatar
Originally Posted by vsocks1
Aaron,
What is the diameter of the flycut?
Old Jul 25, 2009 | 03:47 PM
vsocks1's Avatar
I believe the Lindy tool had a diameter of about 2 1/8" - was oversized for the valve somewhat anyway here is a picture:
Old Jul 25, 2009 | 05:55 PM
405HP_Z06's Avatar
Here you go:
Old Jul 26, 2009 | 12:15 AM
vsocks1's Avatar
Here you go:
Thanks!
