Cam timing question! What is my tolerance?
Old Jul 27, 2009 | 10:32 PM
Prerun4fun13's Avatar
Default Cam timing question! What is my tolerance?
Ok so im degreeing my cam right now and i found it to be at 110.25* ICL. The cam is to be installed at 111* ICL per the cam card. Now i know there are times were you can have + or - 1*. Is this the case?
Any advice is appreciated
Thanks
Old Jul 27, 2009 | 10:35 PM
A_VAS's Avatar
you are good. If you zero out and remeasure, you might get 111 on the dot LOL
Old Jul 27, 2009 | 10:56 PM
I went back and tried again and i got 110.5
hmmmmmm
Old Jul 28, 2009 | 02:25 AM
PREDATOR-Z's Avatar
You are fine, less than 1* is pretty much spot on.
Old Jul 28, 2009 | 11:25 AM
JPH's Avatar
JPH
Thanks
Go by the IVO @.050 on the card. Centerlines are deciving?
Old Jul 29, 2009 | 10:48 AM
A_VAS's Avatar
unless you have a hellish big diameter wheel...I don't know how you can distinguish 1/4 of a degree.
Generally if it's out of whack by 3 or 4 degrees...I would dial it in...otherwise call it good.
Does your card have valve events at .050 listed? Like JPH said this is better checking point. Asymmetrical lobes will change the c/l reading
Old Jul 29, 2009 | 11:53 AM
Red99TA's Avatar
How would you do this? I ask because I honestly don't know (I just degreed mine a few weeks ago using the ICL from max intake lift +/- 0.050"). I have a cam doctor printout that lists all the info for the cam as ground.
Old Aug 2, 2009 | 02:43 PM
JPH's Avatar
JPH
A degree wheel and a dial indicator.
