Changing valve springs sucks..
The Crane tool > Every other valve spring tool on the planet.
Also, use the TDC method for holding the valves up rather than trying to stick an air fitting in each cylinder. Much easier this way.
Put #1 at TDC, do cyl 1 and 6. Rotate 90*, do 8 and 5, rotate 90*, 7 and 4, rotate one more 90*, do 2 and 3. Done.
