Trying to decide on a DD cam
Old Aug 23, 2009 | 01:28 PM
Matts94Z28's Avatar
Default Trying to decide on a DD cam
I need a good healthy cam with great power under the curve for my bolt on 2001 camaro. I would like to stay in the 228-236 duration... The car is a t-56 car with a 3.23 gear, the rear cam out of an auto and I do no plan on putting a gear in. I don't want a cam that makes a ton of peak power, I have been down that road in the past and want to avoid that. There seem to be a ton of cams out at the moment with all the new lobes and such that perform well with stock cubes and head. Does anyone have a suggestions as to what I should be looking for?
I was thinking about one of the EPS or HKE grinds... but I am looking for opinions and feedback. Let me know!
Old Aug 23, 2009 | 01:35 PM
223HAWK's Avatar
I liked my LS6 Hot cam I had for a while, kinda miss it now...
Old Aug 23, 2009 | 02:31 PM
MelScrilla's Avatar
If you want to stay with the 228 you could look at the new 228/228 from TSP I dont think it on their website yet but they have a thread about it in the dyno section.
Old Aug 23, 2009 | 03:19 PM
Matts94Z28's Avatar
Hot cam is a little too small for my liking... I do want to make good power. I have looked at the 228R and I was impressed, but I think there may be a few cams out there in the 230 range that would make some nice torque down low and make driving a blast. Then again, I kinda want to steer away from "typical" cams that most people use. My best bet would probably be a custom spec from one of the sponsors...
More info would be greatly apppreciated! Dyno sheets and feedback would be great.
Old Aug 23, 2009 | 04:34 PM
RS_SS69's Avatar
I run the 228R, great cam, great under the curve power! Streetability is awesome, has good torque down low but still pull hard from 3k on up. I run 3.73 gears and it works out really well for DD. If you want torque go with a custom grind similar to the torquer v2.
Old Aug 23, 2009 | 09:51 PM
Matts94Z28's Avatar
I have also looked at the Torquer cams... I know a few people that run them and they make great power down low. Would you mind posting a dyno sheet, if you have one?
Old Aug 23, 2009 | 10:53 PM
RS_SS69's Avatar
Were set to go on the dyno after a clutch swap! I would have to download my 02 z28 dyno without a tune and 3400 stall and 228R put down 356 hp with the converter unlocked.
Old Aug 23, 2009 | 11:24 PM
navyblueSS's Avatar
+1, great cam. My car put down 400hp, 375tq through a Yank 3600 stall. Car has run a best of 11.66 @ 116 full weight with 3.23 gears, and on 17in M/T drs. Driveability is great and pulls hard to 6600.
Old Aug 24, 2009 | 12:24 AM
TransAmcoupe98's Avatar
I am a fan of the 228r as well. If you have some cash to spend however; I would look into Tony Mamo's "Blue Pill" package. AFR 205 heads milled to your specs with all the fixins and a 224/228 cam. Consistently putting down 450whp and that would be a street beast and drive like stock.
Old Aug 24, 2009 | 12:27 AM
Detoxx03's Avatar
Futral's F 11
Old Aug 24, 2009 | 08:53 AM
johnster's Avatar
Originally Posted by Detoxx03
Futral's F 11
i had the same cam,, car ran 7.50s on slicks{3200 stall} and drove like stock with a tune 228/230 575/595 on 114
Old Aug 24, 2009 | 01:06 PM
Matts94Z28's Avatar
Thanks for the input guys! Keep it coming... track numbers, hp numbers and dyno sheets will really help me make my decision. Like I said, I want a nice fat torque curve with a wide powerband. If I go with a shelf cam then it will probably be the 228R or the Torquer v3
Old Aug 24, 2009 | 01:11 PM
ThunderStruk's Avatar
You cant go wrong with the TR 224 camshaft. Great for daily driven cars. If you want a step bigger the 230/224 cam wouldn't be a bad choice. Here is a link to the cams. Both of those have a link to a dyno graph.
http://www.thunderracing.com/catalog...&vid=3&pcid=51
Old Aug 24, 2009 | 01:20 PM
bongva's Avatar
good info in this thread, im also in the market for a cam!
Old Aug 24, 2009 | 01:22 PM
WSsick's Avatar
that new 228 cam from TSP, or preferably a custom grind cam.
Old Aug 24, 2009 | 01:36 PM
ta-stanger's Avatar
I have a custom Comp Cam in 228 230 .588 .591 112. And it gives me some serious low end !
Old Aug 24, 2009 | 01:45 PM
Detoxx03's Avatar
I love this cam. It makes good power and once I hit 100mph it pulls hard.
Old Aug 24, 2009 | 01:48 PM
The reverse split cam that TR just suggested would be pretty bad *** too. Its a cam that does really well without the use of aftermarket heads. I've seen some pretty serious numbers out of those cams.
Old Aug 24, 2009 | 02:20 PM
02ws6NBM's Avatar
what about "streetsweeper" or "tigershark" cam from ed curtis? usually make good under the curve power for a street car.
Old Aug 24, 2009 | 02:26 PM
Those are excellent cams, thrift through some of the older threads on the streetsweeper and you can find some good info.
