compare rocker arms
Old Nov 27, 2003 | 12:59 PM
2001CamaroGuy's Avatar
Default compare rocker arms
I need a set of adjustable shaft mount rockers. What are the differences (quality and fit) of these:
1) Jesel Shaft Mounted Roller Rockers $995
2) Comp Cams Shaft Mounted Roller Rocker Arm $835
3) T&D Shaft Mounted Roller Rocker Arm $835
The max RPM will be 7600 and they need to go under "gutted" stock valve covers (I milled out ALL the insides of the 99+ valve covers) as I don't want to do spacers (or aftermarket covers).
Old Nov 27, 2003 | 01:00 PM
Country Boy's Avatar
Senior Member
Youll need spacers with all of them.
Old Nov 27, 2003 | 01:15 PM
even with the insides gutted
Old Nov 27, 2003 | 03:06 PM
Scott Turvey's Avatar
yup...
Old Nov 27, 2003 | 03:16 PM
Originally Posted by Scott Turvey
yup...
DAMNIT!!!!!!!!!!!!!
oh well.......which rockers are the best for the money
Old Nov 27, 2003 | 04:37 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
What time frame are you looking at? We're trying to get the Patriot rockers ready for release pretty soon
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Nov 27, 2003 | 09:19 PM
Christmas/New Years-ish.......
Old Nov 28, 2003 | 01:11 AM
Jason99T/A's Avatar
I can shift faster than you.
The only experience I have first hand is with the T&Ds. They are an excellet rocker and I would highly recommend them. You do have to run a spacer for them to fit, though.
Jason
Old Nov 28, 2003 | 01:49 AM
masterdill's Avatar
Who makes a valve cover that will clear all of these rockers that is REASONABLY priced?
Who else makes a valve cover that will clear all of these?
A valve cover is a valve cover, unless it is clear and dosen't get blemished over time, why pay more?
Old Nov 28, 2003 | 02:07 AM
Jason99T/A's Avatar
I would recommed using valvecover spacers. I used these awhile back and had good luck with them, and they are quite a bit cheaper than most of the aftermarket valvecovers.
http://www.thunderracing.com/index.c...yid=1114#P3397
Old Nov 28, 2003 | 02:09 AM
4thGENRETARD's Avatar
TTT with masterdill.
But on same note I run Comps Shaft Rockers with a set of Patriot LS1 stage II and they fit under gutted 01 valve covers.
I have even been called a liar for making this statement but who cares, it works for me. Why? I can maybe speculate that the clearance issue is super minimal and that my patriot's heads have a slightly taller lip, but I never measured and compared. all i know is that they fit on my setup.
Old Nov 28, 2003 | 02:55 AM
ssheets's Avatar
Liar liar pants on fire
Old Nov 28, 2003 | 05:03 AM
LOL,see what I mean.
Any ways in good spirit
Old Nov 28, 2003 | 12:16 PM
hmm...so you were able to get the comps under gutted covers
how are the comps working for you? I was really looking at those but had not been able to find anyone who has used them.
