Eagle 383 stroker?
Old Sep 8, 2009 | 12:32 PM
Steve-O's Avatar
Default Eagle 383 stroker?
Anyone here running a eagle 383 stroker kit?
I have been looking into this and wanted to get some feed back on how well it works...
SO if you are running the kit what is your setup ( heads,cam, what eagle kit, and how much whp) ?
I was thinking something along the lines of the ls1 383 stroker kit with trick flow 235 heads with 75cc chambers to make 10.4:1
and I have not decided on a cam yet..
Old Sep 8, 2009 | 12:45 PM
Billiumss's Avatar
I've worked on/tuned a 383 before. They can make good power. You need to swing by so I can go over things with you.
Your only 2-3 miles away from me...
Bill
Old Sep 8, 2009 | 01:16 PM
Steve-O's Avatar
Bill
I assume you are on cr? Do you ahve the same s/n on there?
I will send you a pm etc on cr
Old Sep 8, 2009 | 04:55 PM
yyz28's Avatar
I have the following:
Eagle LS1 4.00-Inch Stroke Crankshaft
Eagle LS1 6.125 H-Beam Connecting Rodsed
ARP 2000 Rod Bolts
Diamond Racing LS1 Forged Flat-Top With -7cc Valve Reliefs, 3.905 Bore
TSP PRC LS6 Stage 1 Heads
TSP MS4 Cam
Long Tubes
True Duals
Fast Intake and Throttlebody
Dyno attached, those numbers are though a built 4L65E and SS3600 (locked)
Old Sep 8, 2009 | 09:30 PM
Steve-O's Avatar
ARP 2000 Rod Bolts
TSP MS4 Cam
Long Tubes
True Duals
kinda hard to read I think I can see 437 tq but can not make out the hp numbers..
Old Sep 8, 2009 | 09:40 PM
Cyris0014's Avatar
Its in his sig
Old Sep 8, 2009 | 10:21 PM
MelScrilla's Avatar
I would think that a eagle 383 would make the same power as any other 383 rotating assembly given the same compression and the top end was the same. From what I read eagle parts are good up to about the 1000rwhp mark after that they got the Lunati or callies dragonslayer stuff.
It seems like eagle makes quality parts.
Old Sep 8, 2009 | 10:31 PM
david vericker's Avatar
Eagle 4.00" crank
Eagle 6.125 H-Beam rods
JE -2cc pistons
ARP L19 rod bolts
See below for the rest of the combo.
Old Sep 8, 2009 | 10:45 PM
yyz28's Avatar
437 lb ft torque, 480 rwhp. I think with some badass heads, 500rwhp is possible even through the automatic. . Nothing wrong with the much maligned 383.
Old Sep 9, 2009 | 08:08 AM
Steve-O's Avatar
That is what I was hoping to hear.. when all said and done on spray I want to make around 650-700whp and hopeing for a little over 500whp n/a. I just thought eagle had a pretty good deal as apposed to the others on their kit.
I was also looking into weisco pistons with lunati rods and the eagle crank... but Then I thought eagle probably did a lot of work to make sure all their rods and pistons etc worked well with their crank... I think I will get the whole eagle kit with trick flow heads and a good cam I should be able to get just over 500whp
Old Sep 9, 2009 | 08:13 AM
86 IROC's Avatar
I doubt the 235's will work on a small bore 383. 215 CNC'd or 220 as cast small bore TFS heads will be a better fit.
To the guy who dyno'd 480 RW... any track #'s?
Old Sep 9, 2009 | 08:55 AM
Steve-O's Avatar
After reading up on them more I think I will either go 215 or 225 but ahve to get it cncd to 72cc chambers so I can get a pump gas friendly ratio...
Old Sep 9, 2009 | 11:24 AM
yyz28's Avatar
Thumbs up
Not yet. Car was dyno tuned 2 weeks ago, and motor only has 1200 or so miles on it at this point.
...I'm also on my 10 bolt and I'm a bit afraid to come out of the hole on my slicks with the extra HP and TQ over the old setup. I'm thinking I will probably install a new rear this winter and be ready for the track in Spring.
Old setup made 430HP and ran 11.7 best and 11.8 regularly. Fully loaded car, 3850lbs with gas and me in it. It's got no cage, so if I hit the 11.5 mark, I'll be about where I want to be.
Old Sep 9, 2009 | 12:41 PM
Steve-O's Avatar
That is good to hear because I am hoping on street tires to just break into the 11s
Old Sep 9, 2009 | 12:44 PM
sscamaroburn02's Avatar
wow very impressive numbers. I am debating if I want to go this route or save up and get a iron 408. sweet ride though!!!
Old Sep 9, 2009 | 01:00 PM
allngn_c5's Avatar
You won't be disappointed if you go with TFS 215's. I am actually running TFS 215's on my 402 but had the heads opened up to a 4 inch bore to Maximize there potential. The 215's untouched will be perfect on your 383 idea. If you want to save a some cash and only give up a few rwhp you could opt for the TFS 220cc "as cast". Either way you go you should be happy. Good solid heads for Nitrous !!
Give Ron @ Vengeance a call (Number is in my sig, and tell him Doug sent ya) for a quote. Vengeance is an authorized dealer for TFS and should be able to point you in the right direction and get you a good / fair price.
Old Sep 9, 2009 | 01:10 PM
slt200mph's Avatar
I was thinkin the same thing the 235s would not be the way to go on a 3.90 bore...the 215s or as cast 220s will be the way to go...but I would shoot for some higher compression...my DD has a 11.4 ratio and I have no trouble with pump gas...59 cc chambers and a .040 gasket give me a real nice quench and no knocks ... plus more power ..
Old Sep 9, 2009 | 01:33 PM
Steve-O's Avatar
They have the range of cc size to what ratio you will ahve... let me go look it up and I will post it
Old Sep 9, 2009 | 01:42 PM
Steve-O's Avatar
here is what eagle says on the performance ls1 383 stroker kit
11.3:1 with 64cc head
11.0:1 with 66cc head
10.4:1 with 72cc head
Old Sep 9, 2009 | 05:14 PM
My SC is 11.4:1 with the GMPP 61cc heads using a stock gasket thickness. The car is tuned for 93 octane on motor,but I normally mix VP 109 and BP 93 at a 50/50 ratio due to the nitrous hit. If your going with TFS heads I'd use the 215's (64cc)...bigger is not always better when putting together the best combo.
