planning 408 stroker build
who sells good but reasonably cheap stoker rotating assembly's im using a 6.0 block and ported 243's probably for heads and an ls6 intake and a good size cam and am gonna be running spray around a 150 shot to start with, this is my first lsx build so any help will be appreciated
sounds like you are kinda in the same boat as me.. I would say what is your goal hp wise to make etc...
If you did a 408 I would get something more like the fast 90/90 manifold and a set of afr heads or trick flow heads. If you are going to putthe money into a 408 why not get the best you can?
LS1Tech Premium Sponsor
We've got great pricing on the 408 rotating assemblies as well as assembled 408 short-blocks!
Let us know if we can help!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
if you are going to build a 408, you are really going to be choking it through ported 243's and an ls6 intake. there has been a few people to make power out of something like that, but not many at all, mostly because its nowhere near its potential. if you are on a tight budget, then i see why youd go that route. if not, there are people making 520+ regularly now . big heads, big cam and a (ported) FAST combo up top is almost a must. let the big cubes breath and itll pay ya back
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
its gonna be a tight budget but if i can find a good set of heads for a reasonable price i will probably go that route but i am definitely staying with the ls6 intake for now i wont have money to get a fast 90 set up
go with which sponsor suits u best. check all of them out and their prices..take ur time.. i went with tsp... they have excellent prices and top notch customer service...
