Ls1 427?
Old Nov 29, 2003 | 01:51 PM
98 T/A raptor's Avatar
Default Ls1 427?
I have been reading about the LS6 C5R 427 Can I get that cubic inch out of my LS1. Also does anyone know of a good set of heads. Thanks.
Old Nov 29, 2003 | 02:00 PM
Bear's Avatar
4.125 Resleeved Alum Block
4.0 Stroker Crank.
8 Cylinders.
428 Cubic Inches. 427 just sounds better so that is what I call mine. Heads are another animal all together. You need to do some research and make your own decision. Good Luck. Bear
Old Nov 29, 2003 | 02:29 PM
Quickin's Avatar
Can C5R heads bolt on to a regular LS1/LS6 block?
Old Nov 29, 2003 | 02:57 PM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
Yes they can, but you would need a custom intake manifold.
Old Nov 29, 2003 | 03:00 PM
SMOKINV8's Avatar
Custom headers too.
Old Nov 29, 2003 | 11:06 PM
Chicago Crew UnderBoss's Avatar
Yes, all you need is a resleeved LS1 alum block (4.125 bore) with 4.oo crank or 6K+!!!! (Use lunati and not Callies).
STROKER HEADS, CALL MTI as the stage III LS6 heads i am running on their 427 C5R block motor which was the first LS6 heads to put a Naturally aspirated 422 C5 LS6 into the 9s (the Colonel) well over a year ago!!!
Old Nov 29, 2003 | 11:21 PM
Quickin's Avatar
So, if I were to [b]JUST[b/] put C5R heads on my 436 stroker and a sheetmetal intake, say the NASTY PERFORMANCE intake, and a set of headers that will fit, what will that do for the RWHP increase????
Old Nov 29, 2003 | 11:26 PM
QUICKEN,
If your able to get that all dialed in plus or minus one or two other fabrications that you need to get that C5R top end to work, etc. i would say you are looking at least a 75RWHP increase over your current set up and maybe 100rwhp more if you bump up the compression with that set up to about 12.5 to 13 to1 compression! HOWEVER<plan on at least 10 to 13K to get this bad boy set up as the C5R heads are HUGE $ as well as the other top end parts neede to get this BITCH set up right!
Old Nov 29, 2003 | 11:45 PM
Quickin's Avatar
Originally Posted by MTI 427 C5 Roadster
QUICKEN,
Besides the sheetmetal intake, what do you mean by top end parts?
How much are just the C5R heads? Can they be ported, or do they come
maxed out?
Old Nov 29, 2003 | 11:51 PM
gator's 99TA's Avatar
i know that raging motorsports just put together and tuned a 427 c5r BLOCK and 6.0L head motor and it made nearly 510 rwhp and over 500 rwtq. this was a "cheap" head setup and ls6 intake.
Old Nov 30, 2003 | 12:19 PM
Quickin's Avatar
Thats virtually the same thing as a 427 LS1/LS6, right? Because a C5R block offers zero power gains over a regular LS1/LS6 block.
How do the 6.0L heads differ from the LS6 heads?
Old Nov 30, 2003 | 04:21 PM
Cal's Avatar
Cal
They have bigger combustion chambers, but still have the good port design.
Old Nov 30, 2003 | 05:32 PM
Jimmyz's Avatar
Yes, all you need is a resleeved LS1 alum block (4.125 bore) with 4.oo crank or 6K+!!!! (Use lunati and not Callies)......
Just curious why you say this about Callies?
Old Nov 30, 2003 | 05:58 PM
Bear's Avatar
I heard one or two bad things about Callies, but If I didnt buy things because I HEARD one or two bad things about that product, my car would still be stock. I have the Callies, but I have not even fired it up yet. Bear
