do heads without cam?
Old Dec 2, 2003 | 04:58 PM
WS6FirebirdTA00's Avatar
Default do heads without cam?
im still debating doing a cam but i was thinking about doin some patriot stage 2 heads. i want to hit 400 rwhp and i will have every bolt on from the EWP, entire intake and exhaust with a cut out too. figure heads might beable to get me there....maybe.....thinking the 5.3L heads or the LS6 heads. any opinions? could i get to 400? i mean i wanna do a cam in the future just not yet...
Old Dec 2, 2003 | 05:00 PM
Kens_02SS's Avatar
The first thing they'll ask you is what cam? Then you'll go from there So tell us what cam are you thinking about?
Old Dec 2, 2003 | 05:27 PM
honestly i dont knwo what kinda cam i want, dont know much about them. but from what i read i want to get something along the lines of a 224 with about .580 lift or so, but hell i really dont know what would be good but i dont wanna go too extreme. would i benefit from getting better flowing heads. i dont know how long it will be before i get a cam really. im really wanting to hit the 400 RWHP mark. can i just do heads? leaving the cam out of it for now, i want opinions on both and then ill go from there, so what heads to get without a cam and what heads to get with a cam around those specs
Old Dec 2, 2003 | 06:28 PM
LIL SS's Avatar
Moderator
I thinkyou can go with heads first and Cam second. Any good custom cam grinder will ask you about head flow and sizing to determin the best cam..
Old Dec 2, 2003 | 06:32 PM
so should i go with stage 2 ls6 heads or 5.3 heads? or a stage one? it wont hurt doin only heads right?
Old Dec 2, 2003 | 09:04 PM
SMOKIN01TA's Avatar
with stock gears and all the bolt ons you can get right at 400 on stock heads and a 224 cam with a 112lsa. and save the 2k+ for a rear and gears which for now is worth much more imo. especially with a 400hp m6. and gears are worth more in the quarter than heads.
Old Dec 2, 2003 | 09:08 PM
so what kinda duration do i wanna run. i guess i might look into doin a cam and upgrading the valve train and doing clutch and rear too as an optin
Old Dec 2, 2003 | 09:12 PM
jrp's Avatar
jrp
SN95 Director
ported heads and a stock cam are a waste. your better off with bolt ons, new cam, and stock heads. whats the point of ported ls6 heads that flow 300cfm@600 with a stock cam that'll still peaks at about 5500 rpm or so. a cam swap is very easy, and you can experiment with different ones quite simply before looking into heads.
Old Dec 2, 2003 | 09:16 PM
i mean i didnt plan on just heads, i was gonna wait until i could learn some more and do my own cam, no way did i wanna just do heads and no cam, thats kinda foolish...sorry if i explained it like i wanted to do that lol
Old Dec 2, 2003 | 09:29 PM
SMOKIN01TA's Avatar
i would go with nothing less that a 224/224 with a 112lsa that will put you really close to 400 one of thunders cars went 430rwhp with this cam and stage two heads i believe, and that was with almost my identical setup. i plan on going with a 230/224 or a 231/237 111 lsa for my daily driver with a good tune on stock heads for now. im looking at 420+ with 4.10and a 12-bolt. which should plunge deep into the 11's on nittos with some 1.65 60fts just as a refference
you deffinatly need a good clutch. im upgrading to a spec 3 eventually.
Old Dec 2, 2003 | 09:32 PM
SMOKIN01TA's Avatar
and you definatly need a new intake manifold. i would start saving for the fast intake. you will see big gains over that ls1 like 15-20 on stock motor
Old Dec 2, 2003 | 09:37 PM
i was planning on the ls6 intake......what kinda lift would be good?
Old Dec 2, 2003 | 09:44 PM
SMOKIN01TA's Avatar
like i said, nothing less than the 224. thats .563/.563 personally if you dont drive it 24/7 go with the 230/224. still daily driveable but might get somewhat anoying all day in town. i really wouldnt mind it.
Old Dec 2, 2003 | 09:50 PM
jrp's Avatar
jrp
SN95 Director
the lsx intake isnt even out yet, wait for a variety of dyno's on different setups to see the actual gains.
as far as cam for a daily driver i'd stick with 224 on the 112. if you want more lift go with the comp grind that has .581 lift over the thunders .563.
Old Dec 2, 2003 | 09:56 PM
SMOKIN01TA's Avatar
it will be out in 6 weeks. thats why i said start saving.
Old Dec 2, 2003 | 09:58 PM
jrp's Avatar
jrp
SN95 Director
it'll be interested to see the results, again, on a variety of setups. not just a stroked/cam'd car thats already pushing the limits of the current ls6 intake but just a lightly bolted on car.
Old Dec 2, 2003 | 10:15 PM
SMOKIN01TA's Avatar
in two different magazines it said that on stock motors you should expect 15-20 over the ls1 and 10-15 over the ls6. not saying its a fact. just what i reading. also said they saw bigger gains on modded cars(internals). so if its so, theres a few more ponies for my stock car. just trying to see whats the best i can get out of my stock motor on nittos. that a way when i do the cam, heads and slicks it will be smokin
Old Dec 2, 2003 | 10:18 PM
SMOKIN01TA's Avatar
by the way, i think im starting to push the limits of my stock drive shaft. what you think
Old Dec 3, 2003 | 12:03 AM
Jabroni's Avatar
Sure, you can do the heads but don't expect the world. You'll only really be able to use them to their potential after a cam swap, of course. This is not normal practice, however, because an aftermarket cam will net the highest gains just by leaving the stock heads on.
