Those that had a cutom grind done come on in...
Old 10-12-2009, 03:09 PM
99WS7's Avatar
Default Those that had a cutom grind done come on in...
So its time for a new set up and I really think from searching around going the custom grind way is the best thing to do. I want a more low to mid with some good top end but not like what I have now which is mid to good top end with the MS3. So who all did you use and how did you like there service. I don't want to start a war on who is better or what ever...just trying to see what you peeps have to say about your experience. Thanks.
Old 10-12-2009, 03:23 PM
MM98's Avatar
Well as I mentioned in your other thread, I've been chatting with Geoff @ EPS... Basically wanting the same as you, more bottom and mid-range power... He spec'd a 226/234 on a 113... Don't remember the lift #'s, but pretty sure they're around the .600 area.. The thing I really like about the eps lobes, is that they are making really good #'s but, are more valvetrain friendly and can be ran with a behive spring.
Old 10-12-2009, 03:56 PM
99WS7's Avatar
whats the deal with the eps lobes...Im not to familiar with them.
Old 10-12-2009, 04:05 PM
ae13291's Avatar
just ordered my custom cam this morning! i went with thunder racing i ordered something very very similar to the cam up above . i had 1 question (sorry for hijacking the thread) what is the cam grind #? i only had lift, duration and LSA but the guy asked for 1 more # That i was never told.
Old 10-12-2009, 04:31 PM
MM98's Avatar
ae13291- he may have wanted to know what ICL you wanted.. 112lsa +4 degrees advance= 108 ICL.
99WS7- They are a fairly new lobe designed for EPS.. Im pretty sure Goeff and Patrick G. have been using them with really great results... My take is that they are a good power making lobe that is very stable at higher rpms and less wearing on valve springs.
Old 10-12-2009, 05:18 PM
chrs1313's Avatar
this is exactly what you are looking for...
230/230
.612/591
XFI/X-ER
111+2
comp custom grind
Old 10-12-2009, 06:37 PM
99WS7's Avatar
ae13291....let us know how that cam works for you
mm98, thanks for the info bro
chrs1313, that looks like a nice cam...only thing Id a little concerned with is the split light design as I dont know if Im gonna continue to spray every now and then. I always though it was better to have more lift on your exhaust then intake with n20.
Old 10-12-2009, 08:59 PM
ae13291's Avatar
yea i think thats what it was he then emailed me and asked what is the centerline i wanted. ok the cam i ordered is 226/232 .609/.604 113LSA so what centerline do i need? humm i am going to make a new thread about this sorry for the hijack
Old 10-12-2009, 09:14 PM
adam1803's Avatar
Your best bet is to have Pat G spec you out one. I had him do mine a few months ago and i'll never pick a cam on my own again. He got exactly what I wanted out of the car, and Geoff at EPS got my cam to me really quick too.
Old 10-12-2009, 11:26 PM
02*C5's Avatar
Since you have an idea in mind then all you need is some one to spec out your cam. I had Lloyd Elliot spec out my cam and heads. Great job, the moron that put it together while I was deployed used the wrong lifters so I had to go in and replace the lifters after that it ran great 232/238/ 600/600 109 lsa. Lloyd is very old school and a straight shooter.
Old 10-12-2009, 11:51 PM
ae13291's Avatar
sure thing
Old 10-13-2009, 01:39 AM
'02 WS6's Avatar
Pat G spec'd ordered from Geoff @ EPS.
227/235 .617/.621 112+2 spec'd.
Came out to be...
227/236 .616/.623 112+2 on LSL lobes, ground and shipped to Geoff for final inspection (which is cool, so then you actually know your cam specs and not an estimate), then shipped to me. Couldn't be happier.
Old 10-13-2009, 01:45 AM
LS1-NAVY's Avatar
pm pred-z or fill out sheet n pay 25$ to pat-g
Old 10-13-2009, 08:12 AM
02ws6NBM's Avatar
i'll throw Ed Curtis in the mix.
There are a few good cam guys for the ls1. Just do a search for each guy, find some results of their custom cams and make your decision of who to go with.
Old 10-13-2009, 03:59 PM
99WS7's Avatar
thanks for the post guys...got some good info. Only thing is I really need to start researching the different lobes and what not...not to clear on whats the diff from say LSL lobes are to EPS lobes?
Old 10-13-2009, 04:11 PM
NemeSS's Avatar
prolly be best to contact the people spec'ing them. since most of that is proprietary info.
i had my cam spec'd and my engine makes 490rw with unported heads
Old 10-13-2009, 07:11 PM
SOMbitch's Avatar
ae13291 chrs1313, that looks like a nice cam...only thing Id a little concerned with is the split light design as I dont know if Im gonna continue to spray every now and then. I always though it was better to have more lift on your exhaust then intake with n20.
I run the same Pred-Z cam but with a traditional split because of my cats...230/234 .612/.598. Tons of bottom but carries well.......
FWIW though on that shot you would never know the difference......bigger shot exhaust bias is needed....
Old 10-13-2009, 07:34 PM
1CAMWNDR's Avatar
Another vote for PatrickG and Geoff at EPS. Pat spec'd me a 239°/247° .623"/.623" 110° +2° (108° ICL) and Geoff ordered it. When it came in Geoff stuck on the Cam Dr. (Or whatever measuring system he uses) and verified specs for like $15.00.
Great service from these guys.
Old 10-13-2009, 08:47 PM
99WS7's Avatar
again...great info guys. This is a hard choice for who to go with...Im sure there all good. Damn 1camwndr, thats a pretty big cam...are you street driving that monster?
Old 10-13-2009, 09:17 PM
1CAMWNDR's Avatar
I have enough cubic inches for it; and it is on a single plane intake with a 4 BBL throttle body so it likes the overlap.
Yes, it is my daily driver .
Quick Reply: Those that had a cutom grind done come on in...
