383 build..
make sure to let him know what you have and what you want
Whats actually is reverse split?
For along time last year I had a bad vibration in the motor, I checked everything that I could with out pulling the motor...everything seem fine, so thought that the problem was electical or ecm....put the car on dyno, 2nd pull the car just shut off..did make any noise, just as if someone turn the key back to off. We turn the car over manually to be safe and sure enough we new some thing was broke. Turned out I had broke the crank in two, and twisted 1 connecting rod(8)...that was it for the damage....
I'm pretty sure the problem came form powershifting the car and a F_body/mustang shootout....I had a weak clutch and didn't want to lose as I had posted the quickest times for my class.
If you're just trying to go 11s on motor you're going waaay to big of a build. A stock bottom end with a mild camshaft and stock heads will get you there especially with a nice gear in that 8.8.
just my 2 cents
read posts about reverse splits
read these posts, thread started by predator Z about reverse splits
dyno numbers for tr230/224 on stock cubes
stock LS6 243s 440.6rwhp 414.9rwtq through a 12 bolt with 4.11 gears
towing a boat cam my *** lol
i'm goin with a reverse split but it's not the 230/224, it's the 227/224 and i'm not pulling a boat nor jet ski's lol
They can work very well on stock size engines, however, I highly doubt anyone would spec you a reverse split camshaft for a 383 unless like I said, you intend on pulling a boat or have special interest of needing an insane amount of torque in areas where most of us wouldn't need it.
https://ls1tech.com/forums/generatio...tr230-cam.html
but i see what your saying of course if it's the BBK intake i'm thinking of it's a restrictive intake set-up so a reverse split sound pretty good from what i've been reading i have alot more reading to do about this stuff
It will work, it will work with any cam. Putting a camshaft that was designed around a stock bottom end engine to make great midrange torque into a stroker that is going to make crazy torque to begin with just doesn't seem wise. It will make a shitload of torque where you would never need it (ie. 3k and under) and die out when it starts getting up above 5k.
