New pan and water pump
Old Dec 13, 2003 | 09:42 PM
Turnin'LT4's Avatar
Arrow New LS1 Oil PANs and water pump
I posted this over in the fuel system section. I realized that it was the wrong place to post it.
Hey guys i just got back from MORE performance and they got some new stuff in. They got the brand new Canton Oil pan for LS1 F-bodies, it is really bad *** and they are a distributor for the new Meizer water pumps. Here are the picts on them. If you are interested in either of these call Mike or Amber at MORE performance @ 704-393-8241
Attached Thumbnails New pan and water pump-canton.jpg   New pan and water pump-canton2.jpg   New pan and water pump-canton3.jpg   New pan and water pump-waterpump.jpg   New pan and water pump-waterpump2.jpg
Old Dec 14, 2003 | 03:51 AM
CAMN HAWK's Avatar
FASTEST ALL MOTOR LS1 IN THE COUNTRY
whats the price on the canton oil pan??
Old Dec 14, 2003 | 08:02 AM
FireHawk22's Avatar
Is that for ls1 or lt1 and how much it cost for hte oil pan?????
Old Dec 14, 2003 | 08:49 AM
Reckless's Avatar
Super Moderator
New dry sump pan:
http://www.cantonracingproducts.com/pr_12270a.html
LS1 Factoryh style - uses remote filter:
http://www.cantonracingproducts.com/pr_13270a.html
Old Dec 14, 2003 | 08:54 AM
Scalpel's Avatar
What is the advantage of having one of these?
Old Dec 14, 2003 | 10:17 AM
Reckless's Avatar
Super Moderator
Weight is the biggest factor. The stock pan is quite heavy. Prolly save a few pounds, say maybe 5 or so? It does require remotely mounting the filter, so that keeps the oil a little cooler and increase capacity a bit.
The dry sum pan is a whole different ball game.
Old Dec 14, 2003 | 10:18 AM
Scalpel's Avatar
What does the dry sump do?
Old Dec 14, 2003 | 11:02 AM
Reckless's Avatar
Super Moderator
Allows you to keep the oil in a sump, usually located inside the car somewhere, and remotely feed the motor. I think the intention is to keep the oil cooler, have a larger oil supply, and reduce friction of crank sitting in oil. May have something to do with crankcase pressures also? Never have dealt with a dry sump.
Check this out Levi:
http://auto.howstuffworks.com/question331.htm
Old Dec 14, 2003 | 11:30 AM
Scalpel's Avatar
Great article. Seems like a good mod to do for high dollar motors. Where does the "other" oil pump go for this setup?
Old Dec 14, 2003 | 11:40 AM
HOTROD98Z's Avatar
I beleive the factory style pan is about $500
Old Dec 14, 2003 | 02:45 PM
teamsleep13's Avatar
The dry sump oil system is powered by a crank power oil pump that has one pressure stage and one or more scavenge stages.
It basically sucks oil from the oil pan, or anywhere u route the scavenge lines. It them pumps it into the remote oil tank, which is normally much larger in capacity than a dry sump system.
Then the pressure stage plumbs into the block and pressurizes the oil into the engine.
The biggest advantage is that the pressure in the crank case is almost always negative because its always sucking oil and air from the engine. It also reduces windage tremndously, because there is no oilstorm inside the oil pan.
The oil is normally cooler, and has less air in it when it is pumped into the block because it has a chance to deareate in the oil tank. The oil pan also is much smaller, so you can lower the engine for a better center of gravity height.
Its great if you can spare them expense, but normally its not a street car item.
Hunter
Old Dec 14, 2003 | 04:54 PM
TazmanSS's Avatar
Thumbs up
My oil pan looks cool, More is installing on my 02 ss with many other mods
Old Dec 14, 2003 | 07:29 PM
Turnin'LT4's Avatar
TazmanSS
Yep...is that your water pump too? I thought i remembered Bob saying that it was yours. You have got to get some suspension mods on that thing to be safe on the street. when you hit 3rd it is just going to come around on you.
Old Dec 15, 2003 | 03:09 AM
TazmanSS's Avatar
TurninLt4
Suspension mods will be next on my list, have to begin the savings process. All funds going towards mojo. listed all mods under new ls1 enthus.
