ls7 lifters question?
Old Dec 29, 2009 | 03:27 PM
chrs1313's Avatar
Originally Posted by zacht
i think your looking for a thread labeled "how are your LS7 lifters holding up" theres some info on how people are running them with different cam/pr/spring combos.
yeah you are right i kind of hijacked the thread… I was just trying to get an answer for my build…
Old Jan 2, 2010 | 05:19 PM
Spectre86's Avatar
Originally Posted by 99blancoSS
I would not use a Comp -R instead of an LS7 and I would not use a caddy lifter ever.
IMO you either run the LS7 or step up to a real hi performance lifter. Caddy lifter and Comp-r's are not in the same league as the Morel so I do not ever use them.
any reason behind that? Just curious because lifters are still on the buy list for me
Old Jan 2, 2010 | 05:30 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
comp R are extremely finiky on lifter preload. sometimes it can be hard to find the right spot. for any decent cam, i would use the LS7 lifters. for the more aggressive lobes, i would look at intended purpose, then go from there.
Old Jan 2, 2010 | 05:55 PM
02*C5's Avatar
I bought some lifters off Gaterman Products. They are the Eaton LS1/LS6 lifters that GM put in stock in the LS1 and LS6 engines. I am shifting at 6800 and red line at 7K rpm. I am very happy with the product. The LS7 lifter cup is higher by .050 so you do have to measure and get the right rod size you should always do this with any H/C package. Now the stock lifters work well. I got into a heated discussion about the LS7 and LS1 lifters. I was very well informed and I am using stock new LS1/LS6 lifters from Gaterman Products.
Old Jan 2, 2010 | 09:59 PM
printmanjackson's Avatar
what would be considered an aggressive cam? that seems to be the big question.
at what size cam would you NOT use an LS7 lifter.
Old Jan 2, 2010 | 10:47 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
well it depends on the intended use. you will know them when you see them......most of them are called spring killers. imagine how the rest of the valvetrain is effected
Old Jan 2, 2010 | 11:36 PM
would that not be the threshold to define?
Old Jan 2, 2010 | 11:38 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
it is hard. like i said before, you cannot just say yes it will or no it will not. it is such a gray area it is hard to just say one will or one wont. peoples ideas of what is ran on the street differs, and so does intended purpose. that is why it is so hard to get a straight answer....because there is not one.
Old Jan 3, 2010 | 03:40 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
https://ls1tech.com/forums/generatio...l#post12698685
maybe that thread will help a little. do not let the LS7 lifter problem get blown out of proportion, all lifters CAN fail. there is always a reason though that is normally not the fault of the manuf of the part.
