gm fails again.......lifter
Old Jan 1, 2010 | 08:40 PM
ls2 bait's Avatar
just pulled it out........bearing in the roller took a ****. flat spotted it, smashed the roller, and pitted the cam. happy new year :-)
Old Jan 1, 2010 | 11:34 PM
chrs1313's Avatar
so are you going to have to pull the cam too...looks like I might have to get some morels...what cam size and lobes are you running...also what rockers...
Old Jan 2, 2010 | 12:57 AM
ls2 bait's Avatar
ya looks like the cam is going to have to come out. i have harland sharp rockers. its a comp lsl 247/ 254.
Old Jan 2, 2010 | 02:16 AM
B Layton's Avatar
Does it look like this
Old Jan 2, 2010 | 09:38 AM
Chris05ssTruck's Avatar
Damn man, sorry to hear....2010 is off to a great start for you.
Old Jan 2, 2010 | 10:40 AM
chrs1313's Avatar
hey your not supposed to run 15 hydraulic lifter and one solid...
seriously though i want to avoid this and that is why i am going to be getting some morels...pay now or pay later i guess...
Old Jan 2, 2010 | 10:57 AM
69LT1Bird's Avatar
I think all of these failures need to be tracked against the valvetrain setup.
Exactly what lobes are being used, XE, XER, LSL, LSK etc? That or post the duration at .006 and .050 so the rate can be calculated. Perhaps the aggresive lobes are side loading the roller and that in turn damages the bearings.
What springs?
Lifter preload?
Old Jan 2, 2010 | 11:16 AM
King Nothing's Avatar
ok this is not good to hear am i wrong in thinking this is the same lifter used in all the LSX engine from GM???? why would one not fail in a 505 hp LS7 engine and it would fail in people's engines they build? poor installation maybe? i'm not sayin the OP fucked up on installin this set and the caddy set but if 2 sets of lifters go out on you i'd be thinking about having some help installing the next ones. btw did it happen on the same lifter or was a different one in the engine?
Old Jan 2, 2010 | 11:48 AM
66deuce's Avatar
What springs?
Lifter preload?
i was thinking the same thing..
Old Jan 2, 2010 | 12:20 PM
69LT1Bird's Avatar
Especially since there are Millions of these in millions of vehicles. Every GM truck, for example, since 1999 uses the same lifter or its replacement. The cars are a blip on the radar for actual volume of vehicles with LS based engines. Actually the Buick 3800 also used the same lifter, that volume huge.
When we see failures on here we get concerned but in the big picture the failure rate is very low. It is hard to compare the Morels or Comp failures since there is no real data to say how many have been sold, how many miles or hours used and they certainly won't give out their warranty data.
With all of that said, if you are building a purpose built engine for racing, don't put in the production lifters. The Caddy ones are not meant for daily driving, they have lighter weight components and are for racing. The stock "LS7" is a great lifter when used in most all LSx based applications except the most extreme situations.
I would be willing to help compile data if people post everything needed, getting the exact cam specs will be the hardest since people either don't know all of the data or they want it to be a secret.
Old Jan 2, 2010 | 12:31 PM
sixt9er's Avatar
This is what I had started thinking about in after a post I made earlier. Is anyone having failures with "stock" factory LS7 builds, meaning no engine mods? Or are the failures due to stock parts being used with aftermarket parts? Are the LS7 lifters ONLY to be used with the factory spec cam and lobes or does the hydraulic lifter preload make a difference with the more agressive lobes, causing lifter failure? Oiling maybe?
Old Jan 2, 2010 | 12:45 PM
  #32
nocooler's Avatar
It has little to do with HP - it has more to do with the valve train.
The LS7 has a small cam with very tame lobes and light valve springs.
The OP's car has a big cam with aggressive lobes and heavy valve springs which makes for a more extreme environment for the lifter.
Old Jan 2, 2010 | 01:26 PM
  #33
well then caddy lifters and these LS7 lifters should have never been boughten in the first place if GM wouldn't use a donkey dick cam in their application why would someone spend hella money on the whole application except the lifters???
Old Jan 2, 2010 | 02:25 PM
  #34
Mike454SS's Avatar
I've had that happen before too, sorry about your luck man.
When it happened to me, it was in an LT1, and it destroyed the oil pump too...so it might be worth taking your pump apart and checking it out...if it's ok, the bottom end is probaly ok...if it's hurt...you might want to invest in new bearings before you fire it back up with a new cam/lifters and lose the rest of the engine like I did (I was younger and didn't know better).
Old Jan 2, 2010 | 03:10 PM
  #35
99blancoSS's Avatar
I've got 8 sets in stock ready to go !
Old Jan 2, 2010 | 04:22 PM
  #36
B Layton's Avatar
As I posted prior I had an LS7 fail at 1700 miles. L92 Cylinder Heads, 7.4" Chromemoly Pushrods, L92 Rocker Arms, Pedestals & Bolts, PRC
Gold Double Valvesprings /w Titanium Retainers locks/seals/bases, Comp Cams XE-R lobed grind - 237/242 duration @ .050, .603/.609 lift, 112 LSA.
This happens for a reason is it oiling problems, cam or bad install? does anyone have any thoughts.
Old Jan 2, 2010 | 06:26 PM
  #37
ls2 bait's Avatar
What springs?
Lifter preload?
patriot extremes on both motors. .080 on the caddys i had and .065 on these. per katechs recomendation.
it has more to do with the construction of the peices then anything i would bet. im not a professional engine builder but i do know what im doing. different engine entirely.
+1
at the time i built this motor it was widely regarded as the lifter to use. and 98% of the motors on this site prob have them in there. and gm doesnt use a donket dick cam for reasons such as emissions and driveability etc. it has nothing to do with the lifters they use.
Old Jan 2, 2010 | 06:43 PM
  #38
it has more to do with the construction of the peices then anything i would bet. im not a professional engine builder but i do know what im doing. different engine entirely. at the time i built this motor it was widely regarded as the lifter to use. and 98% of the motors on this site prob have them in there. and gm doesnt use a donkey dick cam for reasons such as emissions and driveability etc. it has nothing to do with the lifters they use.
so was it the same lifter from each lifter failure? are you gonna upgrade to those lifters that were mentioned?
Old Jan 2, 2010 | 06:51 PM
  #39
ls2 bait's Avatar
no. i am still doing my homework on the lifters as i dont intend to tear the motor down again to swap lifters. leaning towards morels right now.
Old Jan 2, 2010 | 06:57 PM
  #40
RARON455's Avatar
I am still trying to figure out how you guys think he could have installed the lifter improperly... I clean mine blow them out, Oil the needle bearings and then soak them the night before install. You put the lifter in the lifter box and then slide them in the bores, IF the guy is capable of doing his head and cam swap, they I highly doubt he screwed up the install of the lifters...
Sorry about your bad luck bro. Hope you have better luck when you put it back together.
