Installation of a cam
Old Dec 18, 2003 | 02:59 PM
TWISTA TA's Avatar
WARNING: BAD TRADER STATUS
Default Installation of a cam
What exactly has to be removed to install a cam shaft? Do you have to re time the engine? I just got a set of kooks lt headers and ls1 edit and I wanted to change the cam while I am installing the headers? About how long does it take to cam the ls1? Would a set of z06 heads make a difference in power. Any advice will be helpful, thanx.
Old Dec 18, 2003 | 03:02 PM
Cal's Avatar
Cal
You have to remove the radiator, water pump, power steering pump, crank pulley, timing cover, timing gear on cam and chain, cam retaining plate, rocker arm covers, rocker arms, and pushrods. No need to re time the engine. It will take all weekend to do it. Don't remove the AC condensor, just swing it up and to the passenger side, that way you don't have to recharge the A/C.
Oh and you will probably have to remove the valve springs so you can replace them with some stiffer ones.
Old Dec 18, 2003 | 03:14 PM
TWISTA TA's Avatar
Thanx for the info!
Old Dec 18, 2003 | 03:18 PM
jmX's Avatar
jmX
Everything you'll need:
http://www.ls1howto.com/index.php?article=23
Old Dec 18, 2003 | 04:04 PM
Cal's Avatar
Cal
Originally Posted by TWISTA TA
Thanx for the info!
No problem! And BTW, I used the jmx site shown above for my install. It's probably the best write-up available for a cam install.
Old Dec 18, 2003 | 04:49 PM
jrp's Avatar
jrp
SN95 Director
Originally Posted by jmX
thats like my bible
Old Dec 18, 2003 | 05:41 PM
Ferocity02's Avatar
I dont think you have to remove the power steering pump, but you do have to remove the oil pump which can be a pain. 4 bolts hold it to the block and two more to a pick-up tube. This is the hardest part to re-install because of the oil ring. If not installed correctly, or perfectly for that matter, you will get low or no oil pressure and have to tear back into the engine to fix it.
Old Dec 18, 2003 | 05:48 PM
Cal's Avatar
Cal
You don't have to remove the oil pump unless you are replacing the timing chain. But, most people do upgrade the timing chain as part of a cam install. Just take your time working the pickup tube back on nice and easy, don't try to force it, and you will be OK. Might not be a bad idea to replace the O-ring as well.
Old Dec 18, 2003 | 05:52 PM
jrp's Avatar
jrp
SN95 Director
yup, right on the oil pump and not having to remove powersteering pump. you only have to remove that on a headswap, and those 2 of the 3 bolts are a bitch
Old Jun 26, 2004 | 08:22 PM
StxVenomz28's Avatar
how long did this take you guys to do? a cam swap
Old Jun 26, 2004 | 08:28 PM
jrp's Avatar
jrp
SN95 Director
damn, talk about brought back from the dead
first time around give yourself a whole weekend. and it depends on all the **** your installing. i did cam, dual springs, pump, dual chain, pulley, intake the first time out so it took me longer then just a simple cam and spring swap alone would.
Old Jun 26, 2004 | 08:52 PM
prolly just doing a Z06 cam w/ either z06 springs or 918 comp
Old Jun 26, 2004 | 11:30 PM
Ferocity02's Avatar
Holy ressurected thread!!!!!!!
Mine took me 5 days... ahahahahaha!! I had some major set-backs by not having the right tools. And I also took my sweet-*** time to make sure everything was PERFECT.
