What is the max compression I can run with 8 psi
This is old school roots style/ Carb'd application- so I don't know how relevant it is to FI/ Centrifugal setups.
I do know that boost is only a measure of the engines inefficency (more or less), so this must be taken into account.
also- if you are going FI, you want the CR to be as low as possible and make it up with boost. 10.5:1 is really too high IMHO for a 427 build. You should have 8.5:1 adn get a bigger blower. If you are in the process of building a motor- and want to SC it, then you need to drop the CR to about 8.5:1.
I'm sure there are a ton of people in the FI section that can elaborate on this.
Depending on how much nitrous is used I would say I'm assuming around 100-150 shot around 600 rwhp with nitrous. probably around 450 give or take some without.
It should run like a raped ape either way.
Why? I can't see what you are trying to accomplish with this setup. You want boost and dope- the result being high hp/ fast times.
Why not get a good FI motor built, the right way, and maybe use a little dope to help it out. It seems like you are a little over zealous on the FI/ N2O mix thing. If a little good, then alot is better.
Why not just spend the money on a hardcore FI setup that will give you what you want? I don't see where the 200 shot of N2O is necessary. But hey- it's your dollar.
