450hp on wheels worth $6500 ?
i'm in the market for a new setup
and i found a fully modded (used) ls1 engine for $6500
it has fully bolt-ons +cam and stock bottom ..
w/ fast 92/92 intake + throttle ,215cc ls6 Heads,custom cam ,ls7 lifters ,injectors ,pulleys ,ls6 oil pump... etc
plz help
does it worth the money ? should i buy or not ?
check this out; used 6.0l 300-500, slap on L92 heads and L76 kit for less than 2000$ Cam+mist stuff is 1K$ pushing it...
You could build a cheap 408 for 6500$
just my 02.
yeah i do know the guy
he's a friend actually .. and the motor has like 1500k on it after he installed all the stuff.
and yeah me current motor has 350/365 on dynojet !!
should i just pick a set of heads and that's it ? 400ish hp ?
Your dyno numbers seem really low for that cam, lt's and ls6 intake.
Was it tuned?
I would pass.... for 6500 you can build a nice little setup yourself and know what you got
now i have the ls6 intake installed and planning to port the TB ..
so i guess I'll add a new set of heads and that's it ? ...
Tune: MOST IMPORTANT!!
good heads: stock 243s - tea tfs 215s ($350-2500)
med cam: you already have
intake: ls6 or fast
ud pulley
exhaust: you have a great start, i would change catback but you can add a cut out for a nice little gain
Stock take-out engines are OK, but wise men once said forgiveness is divine, but never pay full price for late pizza........or buy used heads/cam motors.
At 6500 you have tons of options! Give us a call & we can help put together a package for you!!
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
