LS6 427 Questions
I have an LS6 resleeved to 427ci. I'm begining to put together the top end with my refund and I need some help being pointed in the right direction. The car is a 6spd that will see 80/20 street/strip, dig/roll street races, DD whenever I feel like it, won't see any rain, unless I'm caught in it and be able to make 300 mile round trip road trips ie. TX2K10, Austin, San Antonio. The car will probably see 5-7k miles a year. I already have a 9" rearend w/ 4.11's, so I'm good there. I don't really care too much about stock driveability, and i don't mind working the clutch alot. I plan on the car being loud and mean.
Here's what I'm thinking of going with -
427 ci LS6 11.5 comp.
SD Tune
AFR 225's or 245's - would 245's be too big?
Jesel Shaft Rockers
Comp Cam LSR w/ their recommended spring kit
#1 - Dur. @ .050 I 247 / E 255 Lift @ .050 I & E 624 RPM range 2400-7k
#2 - Dur. @ .050 I 251 / E 259 Lift @ .050 I & E 624 RPM range 2600-7k
OR
Pat G custom cam
Electric water pump & Aluminum Radiator - already have
Kooks 1 7/8 dumped w/ e-cutouts & bullets - already have
F.A.S.T. 102mm Intake/TB - since they don't make the 92mm anymore
OR 102mm Intake w/ ported 9Xmm TB
maybe if I can pickup a used 92mm combo if the 102mm combo is too big
I've searched for similiar builds and it seems that with the other 427 stroked GenIII, that AFR 225's, F.A.S.T. 92mm combo, 1 7/8 LT's is the popular combo. I also see 402-408ci builds using 225-223cc heads, so that's why I'm considering AFR's 245's and the F.A.S.T. 102mm combo. Also, the car may see nitrous, but that's a year or two down the road. That's what I have in mind so far. I plan on calling and talking to AFR, Comp Cam and Pat G also for help. Perhaps they could even suggest an engine builder in the South TX area. As always, ANY help is greatly appreciated. I'm open to all/any suggestions. I can provide any extra info if needed.
Thanks, Aaron
Look up LME in Houston.
SD Tune
Jesel Shaft Rockers
OR
Pat G custom cam
Thanks, Aaron
i hope you didnt sleeve an ls6 block. ls6 blocks get super weak if you mid aka wet sleeve them. ls1 blocks are much better to sleeve.
and they want like $3500 for sleeves and Installation.
Look around for deals on a Good clean used LS7 Block
The world is using our LS series motors now which is helping to keep prices inflated
yeah the old supply and demand
I wish to hell they'd go back to bimmers & Benz's again
Bon
the sleeves are one thing, they can handle the abuse. its the block that im worried. call me over precatious.
I'm not a lsx expert by any means that is why I want to learn!
This made me think a lot about doing this to mine in the future, i would think either a 225-235 head would be ideal depending on how big your cam is. I dont know if the Fast style intake would be able to keep up depending on how high you spin the motor, might want to think vic jr style intake and elbow but that kind of kills the big cam only appearance effect.
