Cylinder Head EXPERTS***
I see all these heads that that have great numbers and then I see the exhaust numbers and those vary greatly between different companies heads. I would really like input from from anyone that designs/helps design heads. Thanks in advance
I will quickly throw in my two cents here.
IMO, the exhaust port plays a larger role than some give credit for (or pay attention to). Not to mention the strength of the exhaust port also helps dictate camshaft selection and usable RPM range. A strong exhaust can help a curve hang on longer upstairs and a weaker one forcing an earlier (lower) peak and a power curve that drops off more aggressively (not desirable obviously).
Its back to the oversimplification of an engine being described as an air pump, but the reality is that's a very accurate oversimplification. If you cant properly evacuate the burnt gases and spent charge you will never get a complete fill of the next fresh charge ready to enter the cylinder. Once that happens your energy from combustion starts to drop off as well as your total power output. Exhaust flow has a larger impact on high RPM power because the exhaust port has much less time to get the job done.
Also, don't get caught up in comparing "advertised" flow numbers....I could go on for days on this topic (see my Interesting Flow Data thread sticky at the top of this page). Inquire what type of flowbench is being used and even if its the same drawing conclusions is a dicey proposition. Awhile back a different site sponsor claimed our 205 heads flowed 265 CFM while we only advertise 230. They aren't using a SuperFlow style (fixed orifice) type of bench and the type of equipment they use tends to read extremely generous on the exhaust side.
The best test of any products worthy of comparison is on the same bench at the same facility (no different than chassis dynos)....this way, whether that bench reads low, high, or in the middle, all the numbers have the same advantage or disadvantage.
Hope this helps....
-Tony
Is this correct Tony?
Bottom line, port shape, chamber shape, valve job, proper port sizing (CSA), and even the shape of the valve all have a significant impact on flow....its the optimization of all these attributes than can separate an average head from a very good head.
Much like an engine, combination is key....you cant just hit a few of those details and expect a top of the line piece.
-Tony
Hope this helps....
-Tony
Thanks Tony, Its definately useful information. Now,....back to the drawing board again. LOL
Also, fwiw, this is somewhat general, but I find that heads with really good upper lift #'s usually are weaker in the bottom lift areas. Again, more critical if you don't plan on running the lift up to and past the max flow of the head.
Runner size, smaller are generally more street friendly, bigger runners are more of a race thing, as they are usually a higher lift/flowing head. Example, a race car with a set of heads that flow 400 cfm at 800 lift, and has an 820 lift camshaft, that leaves the line at 5000 rpm and never sees anything less then 5000 the whole track pass won't care about the power at anything under that mark.... street car that only sees over 5000 maybe 5% of it's life (if that much) is going to care about the 3000 rpm power alot more, meaning port velocity is going to be more improtant, as well as low lift flow #'s
In the end, what is your use for the car, and then what is the power goal? A car that makes a peak of 500 rwhp but makes 400 rwhp at 3800 rpm is gonna feel a TON faster on the street then a car that makes 550 peak and is only making 300 hp at 3800 rpm.
But, that 550 hp car, if geared right, will be faster at the track.
Make sense?
Tony: So what Im getting out of your post is that regardless of cam, its always better to have a bigger exhaust flow through out the curve? Please correct me if im wrong.
That being said, if your intake to exhaust ratio is in a good place (say .8 or higher for the sake of saying) you can get away with less of a split then on a car with a worse ratio, of say .6 for the sake of saying.
A head with a .8 ratio, probably needs about 4 to 5 degrees more duration on the exhasut, a head with a .6 ratio will probably need about 10 to 12 degrees more exhaust duration, a head with a .9 would need just about none at all.... for example.
this doesn't make any since
How about NEITHER does this. Make sure when you call someone out on something, that you dont have crap in your pants at the same time.
How does a 1.5x E. valve move as much air as a 2.0x I. valve? NOT!!
It's cool.... Like I heard one of my co-workers tell the boss after he screwed up last week.... "don't worry about it everybody ***** up every now and then bossman"......lol
http://autospeed.com/cms/title_Flow-...5/article.html
