Best cam only option for my current mods(pt4000)
Don't get too caught up on a custom cam, a lot of OFF THE SHELF cams were designed for CAM-ONLY LS1s and at one time were considered "custom". Give your shop TR, TS, Speedinc, LG, etc a call and ask for their recommendation.
LS1Tech Premium Sponsor
Personally I'd look to the Torquer V3 or possibly the Texas Tsunami camshaft. Either camshaft is a good bit smaller than the T-Rex being discussed, but that's probably better considering this isn't a feather weight drag racer with tons of gearing. I think the smaller camshaft like the Torquer V3 would probably be much more enjoyable to drive & would make within 5-7 peak hp of the much larger camshaft while using over 10 degrees of less duration. Not to mention the Tsunami & V3 have WAY WAY better p/v clearance than the really large camshafts out there.
tsunami
http://www.texas-speed.com/shop/item...d=942&catid=44
v3
http://www.texas-speed.com/shop/item...d=669&catid=44
tsunami
v3
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
At what point does your stall speed come into play when selecting a cam? Im sure you want some torque below the stall speed. but for a street car, when would you want the car to wake up?
I was looking at some reverse split cams. Im guessing they would be good for a smaller intake system since the intake duration is greater? More power under the curve at a lower rpm. But having a 4000 stall would throw that idea out.
Have I limited alot of potential with a 4000 stall for cam only? Should I consider some budget heads?
ss4000 cam only 230/230 cam here, da was great at -800 and car is around 3250lbs havent weighed it in 2 years so it is a best guess...
ive got a built auto with an SS4000, and 4.10s, just installed an f13 from futral. (230/232 595/585 112) thing is a dream, stock heads did 385 rwhp and came highly recommended from some of my friends with way more internal experience. thing is a demon!!
i'm running the same cam as chrs1313 also, and love it. i'm cam only and love the driveability and the power down low. hit a 7.5 in the 1/8th last season and am planning on doing a little better than that this year. full weight and also have a pt4000.
