I need TR224 cam only dyno #.
The car ran 11.50@121 with a spinning 1.7x 60' with the mods listed above.
Jason
It's a great all around cam, very drivable. Just got mine, installing it next week
Also, since this is a daily driver how would the old man cam do from Thunder Racing? Is the Old Man cam compatible with the stock valvetrain?
1. TR224 Camshaft
2. Stronger Valvesprings....Most here run Comp 918's but there are many other choices available. Search around or call a few vendors to see what they recommend. I am running C918's with my setup.
3. Titanium Retainers.....Not necessarily needed but recommeded as they are much lighter than stock and the lighter your valvetrain the better.
4. Hardended Pushrods.....Many vendors sell these and are very much a good idea!
5. All the gaskets and such along with a new crankshaft pulley bolt
That is all the componets you will need for a reliable efficient setup. Are you planning to install yourself or have a shop do it for you? If you are going at it yourself search for cam install articles as there are many on here. After the cam in installed make sure you save enough $$$ for a good LS1 Edit tune as there is no replacement for how much better it makes the car run after a cam swap. HTH
